2005-2014 Side airbag delete resistors and 05-10 V6 front brake "upgrade"
7 Attachment(s)
Hey guys, couple of items available. First is a pair of side airbag delete resistors. These are used when say, you have a vehicle that comes with stock side airbags in the front seats, and you decide to do Ford Racing Recaros. These will cap off / connect to the side airbag wiring harness, and provide resistance so that your restraint control module does not throw an error code (which could mean that your airbags may not deploy in the event of an accident). Only used for a week. I was able to fix my old seats and so I have no use for them.
Cost about $17 new each, both are available for $25.00, this includes shipping to anywhere in the lower 48 states. Attachment 187414 Attachment 187414 Attachment 187414 Also available is 2005 to 2010 V6 brake "upgrade" of sorts. These are the front brake caliper brackets from a 2005 GT. These brackets will allow you to run a 12.4" rotor up front, instead of the smaller stock V6 size. The caliper is exactly the same, it just moves it out further. Using these brackets with some new rotors and high performance pads will give you a low cost brake upgrade. These are available for $40, includes shipping to any of the lower 48 states. Attachment 187417 Attachment 187418 Attachment 187419 Attachment 187420 Let me know if you have any questions. Thanks for looking! |
plugs
Is the airbag delete plugs still available?
QUOTE=whysoserious;6936373]Hey guys, couple of items available. First is a pair of side airbag delete resistors. These are used when say, you have a vehicle that comes with stock side airbags in the front seats, and you decide to do Ford Racing Recaros. These will cap off / connect to the side airbag wiring harness, and provide resistance so that your restraint control module does not throw an error code (which could mean that your airbags may not deploy in the event of an accident). Only used for a week. I was able to fix my old seats and so I have no use for them. Cost about $17 new each, both are available for $25.00, this includes shipping to anywhere in the lower 48 states. Attachment 187414 Attachment 187414 Attachment 187414 Also available is 2005 to 2010 V6 brake "upgrade" of sorts. These are the front brake caliper brackets from a 2005 GT. These brackets will allow you to run a 12.4" rotor up front, instead of the smaller stock V6 size. The caliper is exactly the same, it just moves it out further. Using these brackets with some new rotors and high performance pads will give you a low cost brake upgrade. These are available for $40, includes shipping to any of the lower 48 states. Attachment 187417 Attachment 187418 Attachment 187419 Attachment 187420 Let me know if you have any questions. Thanks for looking![/QUOTE] |
How About These!
https://www.ebay.com/itm/30453904236...Bk9SR6zVxJ2bYg Says Discontinued But Lists Same Part Number as Above For 2005-2014 Here. https://www.fordpartsgiant.com/parts...tra2=&filter=() KC |
Airbag Resistors For Reference!
No Longer a For Sale Thread! Revived For Pictures For a Member! KC |
