Ford stuffs 400-hp EcoBoost motor in '34 Hot Rod
SEMA ’09: ’34 FORD HOT ROD ‘REPLACES DISPLACEMENT’ IN FAVOR OF 400-HP 3.5L TWIN-TURBO ECOBOOST V-6
click for more photos
- Ford Powertrain, Detroit Street Rods and Experi-metal team up to showcase classic ’34 Ford 3-Window Coupe hot rod boasting “first” rear-wheel-drive application of EcoBoost™ V-6
- The first production rear-wheel-drive 3.5-liter EcoBoost V-6 model launches next year in the Ford F-150, followed by a 2.0-liter I-4 in 2011 for the Falcon in Australia
- Dan Kapp, director of Ford Powertrain Research and Advanced Engineering, joins SEMA’s “Driving Green” technology briefing on Tuesday, Nov. 3 to discuss the subject of green performance and EcoBoost’s potential as the “replacement for displacement”
To be introduced at this year’s Specialty Equipment Market Association (SEMA) show, the Ford hot rod will be the “first” rear-wheel-drive application of the 3.5-liter twin-turbo EcoBoost V-6 delivering an estimated 400 horsepower and 400 ft.-lb. of torque – power numbers that easily rival a typical hot rod’s 302-cubic-inch V-8 or even a modern-day V-8 of similar size.
“EcoBoost technology shows that there is a viable replacement for displacement,” said Dan Kapp, director of Ford Powertrain Research and Advanced Engineering, who will be part of a SEMA “Driving Green” technology briefing panel discussion during the show. “As consumers’ demand for fuel efficiency continues to grow, and our commitment to delivering best-in-class fuel economy remains steadfast, it’s important to show that performance does not need to suffer as a result.”
“Hot rod builds provide blank canvases for SEMA member companies and SEMA is uniquely positioned to demonstrate that horsepower and green power can coexist without sacrificing performance or the cool factor,” said John Waraniak, SEMA vice president of Vehicle Technology. “This ’34 EcoBoost hot rod is a fantastic example of modern green technology being applied in a manner that any performance enthusiast would love.”
The EcoBoost family of engines uses turbocharging and direct injection technology to deliver up to 20 percent better fuel economy and up to 15 percent fewer CO2 emissions versus larger-displacement engines.
“The beauty of EcoBoost is that it enables us to downsize for fuel efficiency, yet boost for power,” said Kapp. “We’re able to decrease the size of the available engine – such as installing a V-6 versus a V-8 – yet boost the power using turbocharging to deliver similar power and torque to that larger engine.”
The first EcoBoost engine, a 3.5-liter twin-turbo V-6, launched this year on the 2010 Ford Taurus SHO and Flex and on the Lincoln MKS and Lincoln MKT. The EcoBoost V-6 produces 355 horsepower (365 hp in the Taurus SHO) and 350 ft.-lb. of torque.
Ford has recently announced the first four-cylinder EcoBoost engines, launching in global applications beginning next year. The 1.6-liter EcoBoost I-4 first arrives in Europe, followed by the 2.0-liter EcoBoost I-4 launching on products in both Europe and North America.
Going forward, Ford will shift its powertrain strategy to be built around EcoBoost technology. Under the new system:
- A 3.5-liter EcoBoost V-6 would replace naturally aspirated V-8 engines
- A 2.0-liter EcoBoost I-4 would replace naturally aspirated V-6 engines
- A 1.6-liter EcoBoost I-4 would replace naturally aspirated large I-4 engines
The fun-to-drive nature of EcoBoost engines is leading Ford to introduce these fuel-saving powertrains in large volumes virtually across its lineup. For example, by 2013 more than 90 percent of Ford’s North American lineup will be available with EcoBoost technology, and nearly 80 percent of Ford’s global nameplates will have an available EcoBoost option.
By 2013, global EcoBoost volume throughout the Ford, Lincoln and Mercury vehicle family is expected to be 1.3 million units, with up to 750,000 sales coming from North America alone.
’34 Ford EcoBoost hot rod project
Detroit Street Rods’ latest build is a 1934 Ford and is a joint venture with Ford Motor Company and Experi-metal. In this ’34 application, the EcoBoost engine is configured for rear-wheel drive and is coupled with a Tremec five-speed manual transmission.
“The decision to use the EcoBoost engine for our powertrain on this project was an easy one in that it gave us the opportunity to combine the iconic ’34 Ford sculpted body lines with the advanced technology of the EcoBoost powerplant,” stated Robert Smith, president of Detroit Street Rods. “The result is the perfect hot rod marriage of advanced technology for power and legendary automobile design.”
While the stock Honeywell turbochargers that drive the EcoBoost engine are used, they were repackaged to fit the engine bay of this all-steel replica body. The engine configuration and turbocharger packaging was dynamometer tested by Ford Powertrain for proper calibration of the engine electronic control module (ECM). In addition to the all-stock engine, other components including the fuel pump, ECM, fuel pump module, fuel pump processor and drive-by-wire throttle were utilized in their original production configuration.
The body is from Steve’s Auto Restoration and is the recently released 1934 Ford 3-Window coupe. The complete body and fenders are from brand-new tooling, and are designed, stamped and manufactured by Experi-metal in Sterling Heights, Mich. This “replica” ’34 features all-steel construction, full fenders, running boards, electronic power windows, air conditioning and custom bumpers.
The engine was repackaged and fitted with an engine plate adapter to mate with an aluminum flywheel, performance clutch and a Tremec TKO five-speed transmission. The turbochargers were repositioned to the front of the cylinder heads and custom aluminum tubing was used to route the air from the custom air cleaner through the air-to-air intercooler. The exhaust gases are routed from the cylinder heads through coated headers, through the stock wastegates, and pass through large custom exhaust cones located outside the engine bay and just above the front fenders.
Some one better be able to be there and post us up some great pictures of how this engine compartment looks.
Any other pictures would also be welcomed. Please and thankyou.
The drawing of the intake makes me think that each of the 24 valves has it's own separate runner from a plenum that is obscured by the hood. That would be a trick!
Some pics elsewhere showed a custom welded stainless tubing exhaust manifold that was not an equal-length tuned header design--an area where even more power might be extracted from that 3.5L V6 quite easily.
The turbos are in front of the engine block, an unlikely spot for future production vehicles, although they do look good up front!
The best thing about this engine is that Ford made a real effort to use lots of production EcoBoost parts--whereas Chevrolet would have emptied several aftermarket catalogs if they had built it (Is that suggestive that Chevy knows how insufficient their OEM parts are? Yes, Virginia, that actually IS the reason so many competition Chevies are buried underneath every aftermarket decal known to Man.)
Great effort! But I'm kinda leery of all this V6 emphasis--in the long term that can't be good for those of us with Eights as our middle names. I know sixes got the short end of the stick ever since the Flathead was introduced in 1932, but the Equal Rights Amendment does not apply to automotive powerplants. OTOH, slapping down a Camaro is always a worthwhile pursuit, be it with an eight or with a six!
Greg "Eights" Ates
RWD configured ecoboost 3.5-- I wonder if this is a preview of an upcoming F150 or Mustang engine?
