-   SN95 Mustang (https://themustangsource.com/forums/f693/)
-   -   PLEASE HELP ME convert top and rear window problem (https://themustangsource.com/forums/f693/please-help-me-convert-top-rear-window-problem-524505/)
Brian Berthold Aug 23, 2013 10:35 PM
so my convert top is pulling away from the rear window lil bit on the top lil bit on the bottom of the window and both sides(pass and driver) are completely unglued i have found the glue to use but can someone tell me this what part of the cover should and shouldn't be glued?
i guess what im trying to ask is is the top to be glued ALL the way around the window or just the top and bottom??
can someone post a pic with areas marked where it should be attached
this is my first mustang and first convert
thank you much
JFlakes Aug 24, 2013 12:24 PM
What kind of spray did you get,, I'm having the same problem with mine.
Brian Berthold Aug 24, 2013 01:55 PM
Rhino Glue
http://forums.corvetteforum.com/c5-g...-refasten.html
AzPete Aug 24, 2013 02:11 PM
This is on my '02...
The window is glued to a panel that lays under the actual convertible material you see when the top is up. It is glued on all sides. The main top material is not attached to the top or sides of the window.
At the bottom of the glass, it is glued to the actual material you see when the top is up.
Brian Berthold Aug 24, 2013 02:34 PM
ok just to confirm glue the bottom of window to my saddle (tan) color top and leave sides and top alone correct ?
AzPete Aug 24, 2013 05:55 PM
The window is glued all the way around.....just not to the convertible top you see on the sides and top of the glass. I can put my hand on the glass and slide it between the convertible top and the rear window panel...
If you search for Mustang convertible top rear windows, you will see that the window is attached to a separate panel (this is the panel you see between the glass and the trunk panel trim) and not attached to the top material you see.
The top without the rear window and panel it is glued to....no glue touches this part pictured
http://stevesmustangparts.com/store/...7652700-PB.jpg
This is the rear window...
http://thumbs4.ebaystatic.com/d/l225...Y6vrVWbzkA.jpg
Brian Berthold Aug 24, 2013 08:24 PM
ok cool beans i have about 4-6 inches on the bottom that i have to fix then :-)
