PI SWAP.
Is $550 a good price for some 04GT Pi heads and intake? What else will I need and for those who have done it how much was the labor on the install? Want to do this but do not know if this is a good price.
After what I'm going through right now, I'd have the valve seals checked before dropping the heads on. Much easier to do it now than to have the heads pulled again later.
You can find heads as cheap as 90.00 and the most I've spent is 50.00 for the pi intake most I've spent for the pi heads is 200.00 good luck I have mine for sale right now for 250.00.
Originally Posted by true fusion sports
(Post 6635007)
I just did my own full pi swap. Bought the heads and intake for 250. You might want to consider also buying the temp sensor adapter off ebay ($10). It only took me 2 days with basic tools and a torque wrench. While I had the heads off I also took the time to install some new headers. It is well worth the swap but not for 400. Keep looking, there are some good deals out there. Its a fairly simple job to do yourself, just dont forget to replace your head gaskets too.
Joe 96 pi swap |
Yep 250 for all then head gaskets and needed gaskets
Also cams and valve springs you will pay for they are not cheap.
Mine came with
Mine came with stock valve train not after market
Yeah mine came with to bu it was the stock pi valve springs and cams low miles at that and from an 04 gt very clean paid 90.00 for the pair 50.00 for the pi intake good combo for the price
| All times are GMT -6. The time now is 06:00 AM. |
