Help! 95 Mustang 5.0 convertible electrical problem.
Dear frends!
I`m write from Latvia. somewhere in a short circuit - burned out fuse #8 I disconect all positons, but do not care Not working - power mirrors, central lock, radio and cd changer, map lights, couretsy lights, wipper/washer, all gauges, electronic flasher relay connect all time an don`t work In engine compartment all fuses is ok, but in IP panel burned #8.... Engine works I see in IP panel other side 2 wires - green/yellow(go to gauges and radio) and yellow???????? I dion`t find in internet and haynes book correct diagramms |
All those are definitely not just one fuse. Here:
http://www.veryuseful.com/mustang/te...#95-95Diagrams Where you'll find this: http://www.veryuseful.com/mustang/te...5-Fuse-Box.gif Which shows that your list of things that do not work includes fuse 8, true, but also fuses 2, 11, 15, 18... And underhood, there's two or three fuses for those as well. This seems very bad, electrically speaking, and may indicate you need new fuse panel(s) and/or electrical work done beyond just the parts these fuses protect... That page should have what you need for tracing it out anyway... Good luck to you! :nice: |
