A crapload of questions
A what does ford recommend for oil weight? (no personal recommendations please)
B Tire pressure?
C does the head gasket problem apply to this engine too? (I know my 94 had that problem)
D How come no K&N full length kits? Any equivalent? (i really really really dont like the chrome tube with the mac kit)
E I keep hearing this stupid squeaking noise comming from the back is it the rear fold down seats or suspension or what?
F If i remove the bottom of the rear seat is it easly replaceable? I found alot of pens in there and wanna go for the rest.
G If i go to a detailing shop, how much does it cost on average and what all is done?
Can you tell i just got a new stang and am ****?
B Tire pressure?
Recommended in the owners manual is Motorcraft 5w/30
B Tire pressure?
There should be a sticker in the glove box telling you this, it is model and wheel specific
Pass
Yes, it just clips back in
Definately
B Tire pressure?
Pass
Definately
Originally posted by forddude1416+August 9, 2005, 6:08 AM--><div class='quotetop'>QUOTE(forddude1416 @ August 9, 2005, 6:08 AM)</div><div class='quotemain'>
C does the head gasket problem apply to this engine too? (I know my 94 had that problem)[/b]
Ford supposedly fixed the problem after 95, but I would still keep an eye out. I know I havent seen alot of 99+ v6's to have the gaskets blow.
<!--QuoteBegin-forddude1416@August 9, 2005, 6:08 AM
G If i go to a detailing shop, how much does it cost on average and what all is done?[/quote]
Most detail shops I have seen offer different "packages" what is done depends on how much you want to spend.
The sticker with the tire pressure requirements might also be inside the driver's door jam. I know 03/04 cobras have it listed inside the gas cap, which is 32psi cold, which is what most regular passenger cars take.
For the noise in the back end of the car your best bet is to take it to a shop and have them look/listen to it.
