Evilmunky |
6/28/18 07:51 PM |
97 Ford Mustang GT. Vert. Brake light prob.
Hey guys I'm new here not sure if I'm even doing this right but, I need some help or at least a direction to go. Ok on the 97 it has the 3 separated brake and tail lights on the back, 3 on each side, my 2 inner lights are not working the far inner on each side when you hit the brakes, but the outer 2 on both sides are. I figured maybe might be the brake light switch so I ordered one from LMR but I haven't installed it yet but I was thinking,.. looks like the other lights wouldn't work either, and it's not the bulbs I checked them all everything's is good except the far inside brake lights on both sides. Has anyone had this issue or might know what I could check? And something else I think is weird if I hit my brake pedal and hold it for an amount of time like at a red light there's this weird chatter that comes from under the dash and I finally found that noise was from the relay for the turn signals and emergency. I wonder if that relay would have something to do with the brake light issue? I know all the lights worked before and I don't remember that relay sound but I know the brake lights worked after that relay noise started.
