2004 Mustang GT - No start - ECM replacement
I have a 2004 GT, 35k miles with 5 speed manual trans that won't start. It will turn over.
The shop is telling me that they can't communicate with the computer and that it needs to be replaced and it will need to be programmed by a dealer. They are trying to find me a used unit. I've been doing some research on what could have caused this. I think I read somewhere that there was some type of leak that would short the ECM. Does anyone know if that's true, and if so, what leak? Also, where can I find the part number for the ECM for a manual trans mustang? Could this be PATS related without the ECM being bad? I find it difficult to trust shops these days after so many issues with them. Any insight into this situation or what I should expect would be greatly appreciated! |
I don't recall issues with a leak in those years, but in the 05 and up I do. Think it was a drainage hole in the cowl area that would get blocked and run into the passenger side foot well kick panel area where the ecm was, not 100 percent though.
PATS would have been my first thought, but there are guys on here with a wealth of knowledge I don't have. My first question would be does it have fuel at the injectors and does it have spark. |
BTW, a 35k mile 04 is impressive. Exactly the kind of cars I've always looked for when buying.
4 Attachment(s)
@GuitarGuy777
Originally Posted by GuitarGuy777
(Post 7074182)
The shop is telling me that they can't communicate with the computer and that it needs to be replaced and it will need to be programmed by a dealer. They are trying to find me a used unit. I've been doing some research on what could have caused this. I think I read somewhere that there was some type of leak that would short the ECM. Does anyone know if that's true, and if so, what leak? Also, where can I find the part number for the ECM for a manual trans mustang? Could this be PATS related without the ECM being bad? I find it difficult to trust shops these days after so many issues with them. Any insight into this situation or what I should expect would be greatly appreciated! If Your Shop Can't Program a PCM & PATS Keys Might as Well Put the Car in a Shop That can. The Pcm Will Need to Be in the car to Reprogram. The Aftermarket Does Supply Reman PCM'S and With that ID# It Should Not Be That Difficult to Locate One. Can't Tell for Sure Though Without the Number. I would be Happy to provide the Listings if they are Out there. I Have Included a PATS Info PDF. Maybe Helpful, See Second to Last Paragraph. KC |
(Post 7074183)
(Post 7074184)
(Post 7074186)
@GuitarGuy777
The Number For the PCM Should Be on Original Part it Should Be Similar to 1R3T-12A650-A1A In Format. If You Don't Have it Send Me Your Vin to clevparts@aol.com and I Should Be Able to Supply Oem ID# & Part Number. LMK in Forum if You Send It. If Your Shop Can't Program a PCM & PATS Keys Might as Well Put the Car in a Shop That can. The Pcm Will Need to Be in the car to Reprogram. The Aftermarket Does Supply Reman PCM'S and With that ID# It Should Not Be That Difficult to Locate One. Can't Tell for Sure Though Without the Number. I would be Happy to provide the Listings if they are Out there. I Have Included a PATS Info PDF. Maybe Helpful, See Second to Last Paragraph. KC Thank again for your info and response! I'll update the thread with the resolution when it's all done. |
(Post 7074205)
Thanks very much for your time. I talked to shop again and they verified that the can't communicate with the ECM at all and said that PATS only disables spark so they should be able to communicate with ECM if it was a PATS issue. They located a used ECM for me and said that the total for the ECM and reprogram will be about $425. I can handle that!
Thank again for your info and response! I'll update the thread with the resolution when it's all done. Best Regards, KC |
I'm thinking so too! Looking forward to driving it. I think I may get in to autocross with it.
(Post 7074237)
KC |
It's still in the shop unfortunately. The shop replaced the computer but couldn't get it programmed so took it to the dealership and it turned out there was some other failed module under the fender that had shorted the original ECM and they had to order the part. Still waiting for a resolution and it's getting more expensive every day. lol . I figured it could take a couple grand to get it up and running so hopefully it won't be any more than that. I'll update with pics once she's on the road!
@GuitarGuy777
Sounds Like CCRM Relay??? Ask The Question Is Original Ecm Bad Or Just Non Functional Because of Other Bad Part! Should Not Have to Pay For Shop Test Parts! I Always Kept Cores At Store Until Repair Was Done to Be Sure Before Sending Back a Possible Good Part and Later Trying to Retrieve It! Most All Ecm's Have Core Value! KC |
Yes indeed you are correct, it was the CCRM :/ . The shop told me that it caused the ECM to short... whether or not that's true or just that the ECM could not be communicated with because of the failed CCRM I don't know. After getting it running the fuel pump would shut off after about 15 minutes so they had to replace that too. Ended up costing me $2100 when it was all said and done. The joys of buying a vehicle that hasn't started or moved in several years...
Now that it runs and drives I'm going to have to sort out the fact that the AC isn't working and the brake calipers are sticky. With 36k miles on it I should be pretty squared away after dealing with those issues. |
Thanks For The Update. Still With What You Have Spent You Still Got a Deal. A Brake Flush Would Do Wonders as Well as an A/C Service. Make Sure You Got Fresh Fluids in Everything and Then it's Time to Enjoy That Time Piece!
Happy Motoring! KC |
(Post 7074681)
We Have Had a Couple of Members Get Low Miles Older Cars Recently and Fluid Changes were a Hot Topic. For Your Consideration.
https://themustangsource.com/forums/...hanges-549692/ If It were My car I Would Take it on a Shakedown Run to Get Everything Run in and Bring to Light any Weakness. I would Put a Hundred Miles or So On it in a Day Locally so if an Issue Occurred I would Not Have to Get the Car Towed in from Out of Town. I would Drive City, Country and Freeway with Stop & Go's and Try to get all Manner of Different Driving in. Trying Every Component Such as HVAC, Lights Cruise Etc. Get a Notebook and Keep Record of Any Hiccups. Driving Spirited is Fine But Would Advise No Banzai Runs Till Everything Checks Out! Things Like Brakes Can Fail in an Instant Especially after a Long Hibernation. Oh and Throw in a Can of Techron Fuel Additive To Clean Injectors Etc. https://themustangsource.com/forums/...leaner-493878/ Another thought. If you are Planning on Upgrades Etc. I would Get to Know the Car's Feel Before Doing any Major Changes. Otherwise you Have no Point of Reference if Something Does Not Work Out with a Mod. Actually a Original almost Twenty Year Old Car Would Likely be a Homerun at Any Mustang Car Show of Size. Almost a Classic! If You Have Issue Finding an Obsolete Part Down The Road always Happy to Help Locate an Elusive Piece! Anyhoo, Just My Opinion Enjoy it on Your Terms for Sure That is the Most Important Thing! Oh And When You Get All Caught Up Some Pics of That Beauty Would Be Great in Introductions. Happy Motoring! KC |
I did get an oil change, and I'll look into the brake flush as well. Thanks for your input, I'm definitely looking forward to enjoying it!
Thanks for that, I didn't think about the coolant. It is a manual transmission so I do need to check the fluid.
More great suggstions, thank you! I actually put some Techron additive in it as soon as I filled the tank.
And yes it is currently all original though I do want to add racing stripes and the stripes along the bottom of the sides. The thought of keeping it all original is compelling though. Thanks for everything I'll try to get some pics posted soon! |
| All times are GMT -6. The time now is 11:17 PM. |
