17x9 03 cobra rims
Old Mar 22, 2007 | 03:42 PM
Retired's Avatar
17x9 03 cobra rims
Hello!.Glad to be here. Just put the 03 cobra rims (17x9) on my 95 Gt with 245/45/17 tires. She now wants to pull a little bit either left or right when breaking. All rotors and calipers new,new steering rack and outer tie rod ends. Could it be just the extra width of the rim plus the added weight causing this? Maybe someone else has had this problem. Thank you. John
Old Mar 22, 2007 | 08:27 PM
Silver99v6's Avatar
Are the wheels ant tires balanced properly? I may be wrong but its the first thing that I thought when I read it.
Old Mar 22, 2007 | 08:44 PM
mikes rx's Avatar
Does this occur when you stop at stop lights, where the road is well "worn" (ie-where the tires would follow are depressed in the road...the road isn't completely flat). If so, I think it may be due to the wider tire. There's more rubber being put down, so it wants to follow those indentations in the road.
I had this happen to me many times when I had 275's on my 2000, especially slowing down while doing a lane change. Just something to get used to.
Old Mar 23, 2007 | 05:46 AM
Retired's Avatar
17x9 03 cobra rims
Thank you guys for the info. I believe i will just live with it, but i will have my tires checked again and my rims rebalanced. Master cylinder checked out okay. retired
Old Mar 23, 2007 | 10:11 AM
lowblustang00's Avatar
I got 17X9 also, and they love to follow the indentations in the road. Especially at traffic lights. You should eventually get used to it. I did. The better handling I got out of the 9" wide wheels is well worth putting up with it in my opinion.
Old Mar 23, 2007 | 02:19 PM
mikes rx's Avatar
Yep, that's exactly what mine did...especially at traffic lights like you said.
And, like you said, it's well worth it.
Old Mar 23, 2007 | 04:01 PM
nwoh50's Avatar
Any pics guys ??
Wondering more or less if you guys got aftermarket ones or OEM takeoffs ?
I would like to see some Rear 10.5 (03-04 cobra's)on a car..
Old Mar 26, 2007 | 12:33 PM
Scothew's Avatar
Stubborn Bear
TMS Staff
Im wondering if you have the 245/45/17 tires stretched a bit thin for a 9" wheel. Typically tahts the stock size taht comes on the 17x8" wheel and you can run a wider tire on the 17x9.
Old Mar 27, 2007 | 05:47 AM
Retired's Avatar
17x9 03 cobra rims
Thank you Scothew. Yes!, you are right. I should be running 275/40/ZR17 on the front at least. Will give that a try.
Old Mar 27, 2007 | 06:28 AM
mikes rx's Avatar
Originally Posted by nwoh50
Any pics guys ??
I had take off Cobra 10th anny's. They are 9" all around.
Old Mar 29, 2007 | 05:10 PM
SuperSugeKnight's Avatar
I have the exact setup as you. I was told the same, that my front tires are not wide enough.
cozyp828
Dec 13, 2017 05:53 PM
Autotooner
Nov 24, 2017 12:42 PM
trackpack13gt
Oct 2, 2015 08:20 PM
blackhawkkid308
Sep 30, 2015 04:04 PM
Ray11
Sep 25, 2015 12:43 PM
