-   05-09 Interior and Audio Mods (https://themustangsource.com/forums/f692/)
-   -   Subwoofers not working (https://themustangsource.com/forums/f692/subwoofers-not-working-548437/)
Spliced May 6, 2021 12:14 PM
So this is my first time installing a radio it’s a BOSS BV800ACP for the most part everything works and turns on fine sounds good, able to use bluetooth with my phone. But I realized the subwoofers didn’t work. I have stock subwoofers in the doors and in the trunk, none work. I’m probably not the first one to post about something like this on here but I don’t want to mess anything up since I’m doing this on my own.
It came with a few things and the only thing I’m not sure how to set up is the AFDI-5V which I think is why my subwoofers aren’t working but even though it has instructions it’s a little confusing for someone who’s never done this before. So if anyone is good with this stuff and is able to help I’d appreciate it!
https://cimg4.ibsrv.net/gimg/themust...04b1b4ab96.jpg
https://cimg0.ibsrv.net/gimg/themust...68cdf3f6c1.jpg
https://cimg0.ibsrv.net/gimg/themust...06b6d9e72e.jpg
Rrss969 May 25, 2023 03:06 AM
Same problem, please send help
https://cimg3.ibsrv.net/gimg/themust...c77774e30e.jpg
I have the same problem, everything works fine but the subs arent working i dont know what else to do
05stangkc May 25, 2023 12:07 PM
I Just Did a Radio Help Thread For The Masses May Find Some Answers Here!
https://themustangsource.com/forums/...5/#post7075102
Also of Note to Viewers I Have Stuck Threads on the Help & Reference Topics Only and Removed From Sticky any Personal Type Topics.
KC
jeffjohnson34 May 30, 2023 11:47 AM
that smaller connector , plug the 2 rcas in the front output ports then wire the 2 blue/white wires into the blue wire comming from the head unit , ,power antena/subremote .the rca connections send the sound , and the blue wire tells the amps the stereo is on . there are 2 blue/white wires on that connector because there is a separate amp for each door speaker
