Well, I finally figured out WHY the procedure in the manual did NOT disable that annoying seat belt reminder when you first start the car. It's not designed too! The procedure on 92-93 (for 05) or 96 (for 06 I think) is to turn off the "BeltMinder" function. This thing just "reminds" you intermitently to hook up your seat belt.
So, before the normal "just use your seatbelt" crowd jumps in, here is the problem: My normal start up procedure for just about ANY vehicle I have ever driven involves getting in, starting the engine, putting on my seat belt and plugging in the radar detector (if applicable!) and taking car of any "pre driving" business as needed. I always want to start the engine the very first thing to give it a few extra seconds to warm up and get the oil well distributed while I am taking care of the other stuff. And yes, I KNOW I could just buckle up first and then start the car. For those of you with that reply, please feel free to quite smoking and drinking before you post that bit of sage advice... Is there anyway of disabling the bloody seat belt buzzer? I would prefer to just disable that particular function instead of locating and lobodamizing the buzzer itself. If I leave the lights on or something else along those lines, I wouldn't mind the car giving me a heads up. But I want it to SHUT THE HECK UP about the seat belts. I wear them religiously, but I do not put them on in the order that this car seems to think is correct. Stupid "Big Mommy" government.... |
Read the 2005 Owner's Manual - page 92 "Deactivating/Activating the BeltMinder feature.
I have the same 'startup procedure' as you. I like to start her up first then go with the seatbelt. It hasn't bothered me that much, but I'd be interested if someone knows an easy way to disabled that buzzer for just the seatbelt without causing any safety issues. There's probably a sensor switch in the belt housing, maybe I'll fool with it when I get time or if it bugs me more.
You're probably beyond the point of doing anything effective regard changing settings.
I'd look at the belt receiver itself, see what switch gets tripped when the belt is inserted into it and find a way (depending on which way it works) to make it on or off permanently. Just like the traction control, you can't turn it off permanently (that I know of). Just the way the safety stuff works. |
Originally posted by withinavoid@November 10, 2005, 8:04 PM I have the same 'startup procedure' as you. I like to start her up first then go with the seatbelt. It hasn't bothered me that much, but I'd be interested if someone knows an easy way to disabled that buzzer for just the seatbelt without causing any safety issues. There's probably a sensor switch in the belt housing, maybe I'll fool with it when I get time or if it bugs me more. |
Mine doesn't kick on unless I drive for a bit first. In the manual I remember seeing something like if you drive for 30 seconds over 5 mph, the beep will go off if you're not wearing your belt.
Originally posted by tx_pony@November 10, 2005, 6:03 PM Read the 2005 Owner's Manual - page 92 "Deactivating/Activating the BeltMinder feature. So, before you take a half a glance at the title and hit the "reply" button, take a minute to actually read the full title and the post self. Oh, and this is the subtitle (as originally created!): "NOT the BeltMinder function!" |
I will probably have to dig into the car schematics and find out how the switch is tripped and then permanently "fix" it.
My dad used to just yank the buzzer (Or "Dinger" for pittperson! ;) ) and be done with it. Of course, he didn't always wear his seat belt either. I would rather not disable the whole thing, but I am NOT going to listen to the Nanny every single time I start the car. |
Can you explain what buzzing your hearing? Reason I ask is the only noise I get with the seatbelt off is a "ding ding ding ding" after driving it without a seatbelt (not me, my passenger while driving across a parking lot) for maybe 15 seconds or so.
I start it and back out of the garage before putting my seatbelt on and there is no warning noise whatsoever. |
Originally posted by RRRoamer@November 11, 2005, 4:35 PM I will probably have to dig into the car schematics and find out how the switch is tripped and then permanently "fix" it. My dad used to just yank the buzzer (Or "Dinger" for pittperson! ;) ) and be done with it. Of course, he didn't always wear his seat belt either. I would rather not disable the whole thing, but I am NOT going to listen to the Nanny every single time I start the car. The Tone generator is integral to the instrument cluster, so that is not an option. Probably the only way to get the car to do what you want it to do is to go to the connector for the seat belt buckle switch under the driver seat. This is a twelve pin connector grey in color. The wires you are looking for are Black/Lt Blue & Brown/Lt Blue entering the hardshell. Looking at the wiring diagram, it shows a normally open state, with a resistor inline when the circuit is opened. Closing this circuit SHOULD make the warning chime turn off. Legalese....the above is given as information only I cannot be held liable for consequences, damages etc.... But I hope this helps. |
Matt,
Thanks for the info on the wires. If I get time this weekend, I'll give it a shot. I checked again today and the "6 x ding" is definitely dependent on a switch in the seatbelt receptacle. Do you by chance have the schematic scanned and can post a link to it? |
Originally posted by RRRoamer@November 10, 2005, 4:48 PM My normal start up procedure for just about ANY vehicle I have ever driven involves getting in, starting the engine, putting on my seat belt and plugging in the radar detector (if applicable!) and taking car of any "pre driving" business as needed. I always want to start the engine the very first thing to give it a few extra seconds to warm up and get the oil well distributed while I am taking care of the other stuff. And yes, I KNOW I could just buckle up first and then start the car. For those of you with that reply, please feel free to quite smoking and drinking before you post that bit of sage advice... No beeps at all :scratch: |
Nevermind :bang: I just went out to fetch dinner and paid attention :bang:
I'm guess I'm used to cars beeping some poop at me when I first turn it over that I didn't even notice :bang: |
Thanks for the info Matt!
And Tony, you must be DEAF Brother! That ding just goes right through my skull in the morning. And yes, I am talking about the tone generator that makes the dings. In the past, it was a simple electric buzzer and was also just called the "buzzer", so I fell back on hold habits. |
The first thing I did when I got my car home was disable the seatbelt warning. Now don't flame me if this is not what your looking for. The procedure in the manual is for a one time disable. Instead of doing the buckle sequence 9 times, do it 12 times. That is what I did and I get no seat belt warning, buzzer ever.
Originally posted by withinavoid@November 11, 2005, 5:51 PM Matt, Thanks for the info on the wires. If I get time this weekend, I'll give it a shot. I checked again today and the "6 x ding" is definitely dependent on a switch in the seatbelt receptacle. Do you by chance have the schematic scanned and can post a link to it? |
Originally posted by ualpow@November 12, 2005, 2:06 PM The first thing I did when I got my car home was disable the seatbelt warning. Now don't flame me if this is not what your looking for. The procedure in the manual is for a one time disable. Instead of doing the buckle sequence 9 times, do it 12 times. That is what I did and I get no seat belt warning, buzzer ever. And where did you get the 12 times information from anyway? |
I tried the 12 times thing this morning. It appeared to work (the air bag light came on as expected and flashed as expected), but when I shut the key off and then turned it back on, the 6 dings were still with me. Brother.
I'll probably try it one more time before I resort to seat belt buckle surgery to permanantly "fix" the problem. |
I forgot where I saw the 12 times info. It was another Mustang forum though.
All I know is I did that and get no seatbelt warning at all. I'll keep looking for the post. |
I will try it again when I go to lunch today. The CPU is definitely seeing SOMETHING. It lights up at the 12th buckle/unbuckle EXACTLY the same way it des at the 9th buckle/unbuckle, so the CPU thinks something is going on that it should respond to. Strange.
Too bad I can't just take the thing in to the dealer and have them connect to the smart junction and turn the silly thing off. You KNOW there is some line of code in there than can be tweaked! |
| All times are GMT -6. The time now is 03:05 AM. |
