Which Double DIN? HELP??!!
Hey guys, FINALLY back since the crash. Glad to be back in the mix.
I have the Shaker 500 in my '06 coupe. I'm finally sick of the Shaker :banghead: and I'm looking to spend around $200(college student) on an aftermarket double DIN HU to upgrade my system. I've kinda narrowed it down to these three. Which one/other do you recommend? I have an iPod and would like to be able to control it through the HU, but not a must-have. I want something that won't be screaming after-market---something that blends with the OEM dash. I have 2 10" subs with an 760W pioneer amp in the trunk and would like to integrate them into the new system. I am an amateur at radio installation. http://www.crutchfield.com/p_020DUZ3...w&rvm=ShowAllt http://www.crutchfield.com/p_105KWGX...?tp=5684&avf=N http://www.sonystyle.com/webapp/wcs/...52921665801112 Also, does anyone have any suggestions on dash kits and harnesses that I will need to do the install? With little to none electrical experience, would I be able to install the voltage regulator myself? Thanks in advance everyone. Any input/advice/criticism :heh: is welcome! |
Just my .02 worth but I like the first one for OEM looks. Going with Crutchfield they give you everything you need for install.
I just picked up this one from Crutchfield. I know it is a little more than what you want to spend but there are a few pluses. The thing that sold me on the unit was the built in iPod controller with cable and everything. Also, the unit has built in Bluetooth. For myself with a 100+ mile/day commute this was a must.
Because this unit is a "Signature" unit you get life time tech support. The Pioneer Premier units also include an upgraded 2 year warranty. However if I were to pick from the units listed I think the Clarion is a no brainer. It is $50 less than the JVC, has a built in iPod controller and comes with a free remote. Another plus is all of the free install stuff Crutchfield includes. Check out www.sonicelectronix.com too, I have heard some good stuff about them as well. |
Thanks for the input. But Ive realized that the only 2 I can really afford right now are these:
http://www.crutchfield.com/p_020DUZ3...T.html?tp=5684 http://www.sonicelectronix.com/item_...WX-GT77UI.html Out of these 2, which do you guys think is the better deal/better quality, etc...I can't seem to decide between them. Both have free shipping, include the mounting and wiring accessories, ipod interface with usb cord. So which one? Thanks guys. I just need one more opinion to make a decision. Thanks |
One more thing I forgot to ask you guys. Do you think these are even an upgrade to the shaker 500? I read a lot of the reviews and a recurring theme for the clarion was that the sound quality wasn't very good but settings could be adjusted to make it sound better. I read nothing but good things about the sony though. I just want to make sure that I won't be sacrificing quality and downgrading by going with one of these two head units.
Also, how difficult is it to install a voltage regulator? Is there a PDF or install guide for it |
Did you carefully look into how they tie into the Shaker system? It is not clear with the Sony, but for the Clarion it requires a $129 adapter kit to tie into the existing amp system.
I thought that was only for the shaker 1000
Originally Posted by Doogie
(Post 5802140)
Originally Posted by TGREY V6
(Post 5802203)
I stand corrected. Like Doug said you will need the adapter kit for either Shaker system. Both the 500 & the 1000 have amps that need to be controlled.
Either way I would be getting the Clarion unit. I just don't like Sony's and have had the two I owned die and had to replace them. |
Well having to have an adapter pretty much defeats the purpose huh? Well does every HU integrated into the shaker systems need that $130 adapter? Or do some of the more pricey ones have everything I need?
(Post 5802282)
