Bluetooth Mic
I have a Bluetooth mic and want to place it somewhere where no cords are showing, does anybody have a place they have placed theirs and what they did with the cords for no show?
Ummm ... Bluetooth is a wireless transmission technology. None of my BT devices have wires. Maybe I am misunderstanding?
No my head unit does. It has a mic that comes with it and you have to place the mic somewhere in the car. The bt for this head unit is so I can blue tooth my phone to the head unit.
1 Attachment(s)
Here's mine. This was never suppose to be a permanent solution. After a couple hours or installing, I was just like screw it and placed it here. Said I'd come back to it. All the wires were placed away. Used zip ties to keep the wires secured underneath.
Anyhow, its actually worked just fine down there an no one can see it when in my car. So I've just left it there for going on 2 months. No problems at all. Every once in awhile the other person will have trouble but at the same time, my car isn't necessarily quiet either. But its been fine. |
That's a pretty good spot! Nice! Thank you.
Ahhh ... I see.
Maybe run the wire up inside the A pillar to where the sun visor mounts? |
Originally Posted by tu3218
(Post 6552193)
Originally Posted by Nunja Business
(Post 6552203)
Ahhh ... I see.
Maybe run the wire up inside the A pillar to where the sun visor mounts? The other option which My son did in his Fox. Right on top of the steering column between the wheel and dash. You could actually hide it in the cluster..... Another option. Right side of the cluster under the dash cover right were it curves down for the center dip.... |
I put one on top of my steering column
How'd you install it on the steering wheel column?
Originally Posted by pebkac
(Post 6552904)
I would knock that off in a matter of minutes getting in and out.... This is what I would do. The other option which My son did in his Fox. Right on top of the steering column between the wheel and dash. You could actually hide it in the cluster..... Another option. Right side of the cluster under the dash cover right were it curves down for the center dip.... I'll take a look at the idea for around the steering column and dash. |
Ran the wire behind the dash and stuck it to the right side closer to the radio
1 Attachment(s)
This ain't the exact pic obviously but it was about there, just a little further right
(Post 6552998)
His aunt an exact pic obviously but it was about there, just a little further right
It really didn't bother me. However I never used it so when I put my DDX418 in I just took it out
I added the mic close to the visor near the map lights. It works perfectly even with the roof down. Ran the wires through the A-pillar.
http://farm9.staticflickr.com/8526/8...cb65f73ef5.jpg |
1 Attachment(s)
(Post 6552908)
Mine is routed under the dash , up the A-pillar (under the trim) and behind the head liner. If you can find it on search, I have a thread when I installed my Pioneer FH8000 with more pics with how I routed the cable:
https://lh6.googleusercontent.com/-L...0/DSC_6629.JPG Its a great spot, no one has problems hearing me, even with the windows down. It does get loud if I have the defroster on too high |
Originally Posted by Cavero
(Post 6606296)
| All times are GMT -6. The time now is 07:21 AM. |
