Adding 2008-2009 Mustang Factory Ambient Lighting
Old Feb 3, 2018 | 05:13 PM
  #121
Torch_Vert's Avatar
I just picked up an '09 ambient console for retrofit into my '05.
Does anyone have a schematic of the factory console wiring? This thread is helpful, but I'd like to double check wire colors before trying to tidy up the cut harness received from the wreckers.
Old Mar 2, 2018 | 12:58 AM
  #122
Scruffy281's Avatar
Originally Posted by jim010
Now I made the harness that would connect the console to the front LEDs. The length will depend on where you plan to put the front LEDs.
Since I used the same female connectors for the front LEDs and the cupholder harness, all 3 male connectors were also the same.
x2 means that 2 wires need to leave the console connector in order to split off
Console connector to Front LED connector
pin 5 pin 4 x2 make wire (~80cm long depending on where light is to go)
pin 6 pin 1 x2 make wire (~80cm long depending on where light is to go)
pin 7 pin 2 x2 make wire (~80cm long depending on where light is to go)
pin 8 pin 3 x2 make wire (~80cm long depending on where light is to go)
pin 10 tap into black wire from auto tranny connector (~10cm long)
pin 2 tap into light blue/red wire from auto tranny connector (~10cm long)
pin 1 tap into blue w/ yellow stripe wire from smart junction box (~2m long - see below)
the blue and green wire out of the bottom you see will tap into the tranny connector, and the red out the top will go to the SJB
Does anyone know what the 3rd wire to the SJB is for? I’m guessing 12v constant, with the tranny plug giving switched 12v and ground?
Old Mar 21, 2018 | 02:15 PM
  #123
jim010's Avatar
When I did this, I wired it up according to how Ford did it for the 08 car. So this wiring is how you would find it in a car that came with ambient lighting.
But other than that, I don't remember if the SJB wire was for 12v, sorry.
Old May 2, 2018 | 12:38 PM
  #124
jim010's Avatar
I no longer have my 05 GT convertible (my brother has it now) but some of the things I have done to it I can do to other cars.
Since the ambient lighting system in the 07 - 09 cars is an isolated system (not incorporated into anything else, it can be added to any car. All you need is a switch, the control module and the LEDs. I am currently adding this to my wife's 1999 Porsche 911, and even got it to work using a stock Porsche switch. I'l post pics later in case anyone is interested.
Old May 3, 2018 | 12:06 AM
  #125
jim010's Avatar
https://m.youtube.com/watch?v=IS950KlXChs
Posted a video to YouTube. I got the LED in the footwell switch to change colour with the other LEDs as I toggle through the colours in the Porsche. I had to hack the crap out of the switch to make this work. But I am pleased that I got it to work.
Old Feb 5, 2019 | 12:40 PM
  #126
Jamie Hamilton's Avatar
OK, here is what there is so far ...
These are the pieces you will need:
Any idea what the part number is for the last picture is. I need to find one.
thanks!!
Old Apr 17, 2019 | 05:00 PM
  #127
dgtldesigner's Avatar
incase anyone was wondering, I got a console with the light ring, but I didn't have any of the other leds. I ended up finding some in an 08 focus at a junk yard. Same ones for the mustang. They hooked up to the console just fiine. I had to do a little splicing though.
Old Jan 11, 2021 | 09:11 PM
  #128
Sergio Mendoza's Avatar
Help
Please help 9565518368
Old Jan 12, 2021 | 12:55 PM
  #129
Help
Anyone have a video can message me or Instagram svt.checo please
Old Jan 13, 2021 | 07:08 AM
  #130
VGMStudios's Avatar
Tms Mustang Member ------ The Customizer!
What do you need help with exactly?
Old Jan 13, 2021 | 07:28 AM
  #131
Ambient lighting
I need help with wiring
Old Sep 13, 2022 | 04:48 PM
  #132
jcrider's Avatar
2008-2009 stock LED mounting
OK, just got this in the mail today. They forgot to send me 1 jumper wire, and the lower console, but here are the part numbers for you if you are thinking of doing this. I'll post pics this weekend when I put it all together and figure out where to tap into for power.
upper console - 8R3Z 63044D90 BA
lower cup holder - 8R3Z 6313562 A
button - 8R3Z 13D806 BA
lamp covers (need 4) - 7S4Z 13E701 AE (black color)
jumper wire (need 2 - contains the LEDs) for the front - 8R3Z 14A411 B
Jumper wire for the back (contains the LEDs) - 8R3Z 14A411 C
clear ring for cup holder (contains the LEDs) - 8R3Z 14A318 AA
module to control lights - 7S43 13E702 AA
Lower console - didn't come witht he rest of it, so I have to wait.
There you have it. After fiddling with it, it should be quite simple to hook up - I might just tap into the harness for the auto tranny for power.
I'll post pics on the weekend.
Cheers
Does anyone have pictures of a stock 2008 or 2009 mustang with the ambient lighting option.
I would like to see some pictures of the exact mounting locations and methods for the front LEDs.
For anyone interested, the mating connector for the 10 pin female on the cup holder light ring is:
Motorcraft WPT-1175.
I bought one and confirmed it
Old Sep 13, 2022 | 05:00 PM
  #133
05stangkc's Avatar
Here is Some Info from Back in the Day When I Had a Factory Kit I Made up. Ford Also Had a Kit Which Was a Bit Cheesy But I Have Posted a Link. Be Advised Some Links Within the Topic May Have Lost pics Due to Forum Hack Back in the Day and Pic Hosting Sites Going Down. I had all the Pieces to do the Factory Deed Myself as Well for My Shelby But Ended Up Selling it All. Ford Accessory Kit Kind of Mimics Location of Underdash Lights. Good Reference Anyway. I ended up Updating the Accessory Topic. I know you had a Specific Question to Answer and I think that Pic will Help. The Other Updating is to Help Others Considering this Retrofit. If Anybody Needs other Info Just Let me Know,
https://themustangsource.com/forums/...ghting-456419/
https://themustangsource.com/forums/...ng-kit-459352/
KC
It's Been so Long But I think this is Bracket. It's Part of 08-09 Dash! Like I Said It's Been a Long Time. If Anybody Can Confirm and also Post Passenger Side For JC That would Be Great!
See Below this Pic for Added PDF'S FOR LOCATION AND WIRING INFO! C238 & C248 Are UNDER DASH PLUGS For Factory Lamps on PDF 3 Also Found Shop Manual PDF.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Sep 13, 2022 | 05:04 PM
  #134
m05fastbackGT's Avatar
You might also want to consider searching the sub forums by selecting the search function menu... When the search menu drop down window displays, type in 2008-09 Mustang ambient lighting... Hopefully, you'll come across a listing of thread submissions which address the ambient lighting options... Meanwhile, hope you'll find the info provided as useful and welcome aboard!
Old Sep 14, 2022 | 02:56 PM
  #135
jcrider's Avatar
KC
Thanks,
Do you know if that bracket is a separate part from the dash, or just a tab and part of the same molded part.
Old Sep 14, 2022 | 04:07 PM
  #136
05stangkc's Avatar
Originally Posted by jcrider
Thanks,
I believe it is Molded in. No Separate Part to buy That I Can Recall. I think a Tab should Not Be To Difficult to fabricate. I was Hoping Somebody Else Would Have Added a Pic For You!
KC
Old Sep 14, 2022 | 04:39 PM
  #137
jcrider's Avatar
KC
Thanks,
I appreciate it.
Wish I had an 08 or 09 to look at.
I have an 07 PJ.
Old Sep 14, 2022 | 05:00 PM
  #138
05stangkc's Avatar
Thanks,
I appreciate it.
I have an 07 PJ.
HERE YOU GO! They Are Not Much to Look At!
Found Em Here! 2009 Mustang Dash!
https://www.ebay.com/itm/33402002588...3ABFBMnO3B4-dg
Old Sep 14, 2022 | 05:05 PM
  #139
05stangkc's Avatar
Here is Another Angle! Different Auction!
Old Sep 14, 2022 | 05:37 PM
  #140
jcrider's Avatar
Thanks that helps.
Def molded in, def easy to make something up that looks OEMish
