Adding 2008-2009 Mustang Factory Ambient Lighting
Old Sep 30, 2012 | 09:59 PM
  #81
jim010's Avatar
I doubt it is the processor. Those things are built pretty well.
You checked to see if there is power in the wires to pins 2 and 6?
Old Sep 30, 2012 | 10:01 PM
  #82
jim010's Avatar
Saw your edit.
What about all the pins on the module itself?
Old Sep 30, 2012 | 10:05 PM
  #83
jim010's Avatar
Just looking over my diagrams to see if a short somewhere else could be an issue.
  #84
A Dustman's Avatar
Tried on the module too actually, checked over every connector, and every pin. I'll leave it alone for now, blue looks nice. The button was cheap enough from a local ford dealer, and it should be here in a couple days. If that doesn't fix it, I'll have to order a processor online, the dealer wanted stupid amounts of money for it.
Thanks for all your help on this, by the way
Old Sep 30, 2012 | 10:09 PM
  #85
jim010's Avatar
Yes, Canadian dealers charge 4x what they do in the States. I learned that long ago.
I am convinced it is not the processor, but keep us posted.
If I get any other ideas, I'll let you know. Do you have the wiring diagrams?
Old Sep 30, 2012 | 10:40 PM
  #86
A Dustman's Avatar
Hopefully you're right. I'll let you know.
No I do not, do you have a link to them?
Old Sep 30, 2012 | 10:59 PM
  #87
jim010's Avatar
I have the wiring diagram book for the 2009 mustang and 2005. I'll see if I can scan it at work when no one is looking.
Old Oct 1, 2012 | 12:52 PM
  #88
A Dustman's Avatar
Thanks, if it's going to be too much hassle to scan it, don't worry about it
Old Oct 5, 2012 | 12:48 PM
  #89
A Dustman's Avatar
The button arrived today, and just got home at lunch time to install it, and works perfectly! problem solved.
Old Oct 5, 2012 | 03:07 PM
  #90
jim010's Avatar
That's great!
Old May 13, 2013 | 09:59 PM
  #91
jim010's Avatar
I'm bumping this thread again.
I'm getting PMs about this again, so it may be useful to have this thread easier to find.
Been a long time since I did this mod ...
Old May 15, 2013 | 09:54 AM
  #92
jim010's Avatar
As requested, here is the wiring diagram for the heated seats.
Click on it to pull it up.
File Type: pdf
Old Jun 7, 2013 | 03:25 PM
  #93
goldcylon's Avatar
Jim thanks for your write up on this " A Dustman" sent me here as I am about to upgrade my son's 06 GT to 09 Ambinet wiring. Im still awaiting a harness but hope to be good to go soon. GC
Old Jun 21, 2013 | 12:00 AM
  #94
jim010's Avatar
No problem. Keep us posted.
Cheers
Old Aug 23, 2013 | 12:02 AM
  #95
akdoggie's Avatar
I finally, after looking at it in the corner of the garage, decided to install my ambient console into my 07. I got some ambient light harnesses with the caps out of an 11 Flex. I wired them into the harness. I now have the original back 2 LED lights and added 2 to the front. One on each side of the shifter. I also added the 3rd one into the console compartment. You can't see anything in there, so it is a big improvement. All in all, a nice addition, and with the LED's in the console front, instead of under the dash. Worked out excellent and everything works just like original. Great upgrade.
Old Sep 1, 2013 | 10:04 PM
  #96
jim010's Avatar
It has been brought to my attention that the wiring diagram I posted in post #92 is for heated seats (Which I did retrofit, by the way), but this thread is for the ambient lighting.
My apologies. Here is the ambient lighting diagram:
Attached Thumbnails Adding 2008-2009 Mustang Factory Ambient Lighting-ambient.jpg
Old Sep 7, 2013 | 04:47 PM
  #97
Scruffy281's Avatar
Any pics of the setup? Thanks!
Old Nov 25, 2013 | 10:11 PM
  #98
akdoggie's Avatar
I took a video of it working on the bench, before I installed it. Here are a couple pics of it and it's lights, I didn't have a clear picture I could copy from the inside the console, but it is the same light as either of the fronts. Hope it helps you.
Old Jan 24, 2014 | 04:24 AM
  #99
Topless Stang's Avatar
I'm just curious, but what makes this $200 better than the Ford Ambient Lighting Kit?
http://www.cjponyparts.com/interior-...5-2009/p/ILK1/
Part# 8CL8Z-13E700-AA
I'm looking to do something like this in the near future. Pros and cons from those that have ventured down this path would be appreciated!
Old Jan 24, 2014 | 11:32 AM
  #100
jim010's Avatar
I suppose it is a matter of opinion, but I like the inset OEM switch and the figure 8 light in the cupholder. I'm sure you can get all the needed stuff now pretty cheap from the wreckers.
