Adding 2008-2009 Mustang Factory Ambient Lighting
Old Feb 17, 2012 | 10:26 AM
  #61
Scruffy281's Avatar
Glad I found this guide. I will be piecing together my parts list shortly.
I actually want to install this into a carbon center console:
Looks like buying the lower console piece might be ruled out?
Old Mar 7, 2012 | 03:43 PM
  #62
Scruffy281's Avatar
Old Mar 11, 2012 | 09:08 PM
  #63
jim010's Avatar
The lower console will provide the holes needed for the back LEDs as well as a larger opening to allow the new cup holders to fit as well. If you are ok with cutting, you can modify an old one.
Old Aug 21, 2012 | 09:48 PM
  #64
A Dustman's Avatar
Is there anywhere else that supplies these parts? partscheap.com doesn't seem to sell them anymore
Old Sep 17, 2012 | 10:32 PM
  #65
jim010's Avatar
Bumping this thread as there are a couple of pms to me regarding this.
Old Sep 18, 2012 | 10:08 PM
  #66
A Dustman's Avatar
Do you know if it would be at all possible to modify the light ring to fit inside of the stock cup holders? Perhaps by drilling a couple holes, and slimming it down some. I'm looking for a cheaper way to do this mod, and if I don't have to buy a new console, that would save me a few hundred. Do you know of any where to buy these parts for decent prices? I checked Tousley Ford parts, and they're reasonably priced, though shipping to Calgary might not be.
Thanks for your help!
Old Sep 18, 2012 | 10:58 PM
  #67
jim010's Avatar
Check the wreckers. Black Gold here by Edmonton was wrecking a 2008 Shelby that had the ambient lighting. The parts should be quite cheap through the wreckers.
Old Sep 19, 2012 | 06:15 PM
  #68
A Dustman's Avatar
Good thinking, I never even thought of that
Old Sep 21, 2012 | 04:24 PM
  #69
A Dustman's Avatar
Took your advice, and found a complete ambient lighting kit, with the upper console, light ring, controller, front leds all for 120 bucks! I had a trip planned to vernon BC this week, and checked the nearby wreckers, and found this awesome deal. Thanks again, I will be following your install guide this weekend
Old Sep 26, 2012 | 02:08 PM
  #70
MrFullSize's Avatar
But they do!!
Just bought the complete kit from the list, except the lower console, going to cut mine.
But the price has gone up quite a bit. This is todays prices:
From Partscheap.com
7s4z 13e701 ae lamp covers $30 for 4
7s4z 13c788 a processor $65 !!!
8r3z 13d806 ba switch $16
8r3z 14a318 aa clear ring w/ wiring and LEDs $84
8r3z 14a411 b wiring and LEDs for the front $31 for 2
8r3z 14a411 c wirng and LEDs for the rear $32
8r3z 6313562 a cup holder $32 !!!
8r3z 63044d90 ba upper console $250 (Up from $190 !!!)
8r3z 63045a36 bc lower console (Price? no idea)
Total of $540 + lower console.
Old Sep 27, 2012 | 01:09 PM
  #71
jim010's Avatar
Let us know how it goes.
Good luck, guys.
Old Sep 29, 2012 | 10:52 AM
  #72
A Dustman's Avatar
Installed my used kit a few days ago, and it looks awesome. I'm having one problem though, I'm stuck with blue. The button no longer seems to work. I tested the whole kit on my bench power supply before installing it, and it scrolled through the seven colours flawlessly, but as soon as I plugged it in to my car, the button just stopped working. Nothing could have been shorted, I made sure of it.
I have ordered a new button from Ford, so hopefully that is the cause, and not the much pricier processor. I will let you know what happens when the button comes in next week. Has anyone else had this problem? Thanks for all the help in this thread!
Oh, by the way, I didn't have to do any cutting of my lower console in my 07, the upper just dropped right in as if it were made for it.
Old Sep 29, 2012 | 11:12 PM
  #73
jim010's Avatar
So it is on all the time? You can't even turn it off?
Old Sep 30, 2012 | 11:43 AM
  #74
A Dustman's Avatar
Nope, can't even shut it off
Old Sep 30, 2012 | 11:46 AM
  #75
jim010's Avatar
Strange. I'd pull it out again and bench test it before going any further.
Old Sep 30, 2012 | 06:42 PM
  #76
A Dustman's Avatar
I did that right after I found the error in the car, hooked it up to my power supply, and still didn't work. On my bench it seemed that with ever 100 rapid fire button presses it would switch colours, but now that it's in my car, that doesn't even work any more.
Old Sep 30, 2012 | 09:34 PM
  #77
jim010's Avatar
If it stays on blue permanently - can't even shut it off, then I say you may be right. It is the button, or the plug going to the button.
You checked to make sure all the pins in the plug are clean and making contact I assume?
  #78
jim010's Avatar
Does the button even illuminate?
Old Sep 30, 2012 | 09:52 PM
  #79
jim010's Avatar
To help you out, these are what the different pins on the plug to the switch are for:
pin #2 = power
pin #3 = illumination power
pin #4 = ground
pin #6 = switching colours
Hope this helps.
Old Sep 30, 2012 | 09:54 PM
  #80
A Dustman's Avatar
Yup, checked the pins and the button does light up, which kind of worries me that it could be more than the button itself. Hopefully not though.
Thanks for posting that, but I even tried by passing the switch all together, by making contact with the power wire and the wire that switches the colour, which again makes me worried that it's the processor, or perhaps just finicky digital electronics that don't like being bypassed, I don't know
