2008 Center Console w/Ambient Lighting?
Old Aug 15, 2007 | 03:46 PM
mrkabc's Avatar
What is the availability of the new center console with the ambient lighting?
I want it for my car!
Old Aug 21, 2007 | 09:05 AM
05stangkc's Avatar
Pics!
Attached Thumbnails 2008 Center Console w/Ambient Lighting?-100_3097.jpg   2008 Center Console w/Ambient Lighting?-100_3098.jpg   2008 Center Console w/Ambient Lighting?-100_3099.jpg
Old Aug 21, 2007 | 09:09 AM
05stangkc's Avatar
Thanks to Bob K from Michigan for the Sneek Peek at the Ambient Console! He won this at a Car Show over the Weekend! These have not yet released yet from Ford So I have not been Able to Check Retrofitability! Bob Has the First! The Lower Console also Has Led's he was told by the Ford Reps. They Commented it should be an Easy Install but by the Look of that control box on the Bottom I am Not So Sure. I am wanting to put one of these in my 500 and will investigate as parts become available!
KC
Attached Thumbnails 2008 Center Console w/Ambient Lighting?-100_3100.jpg   2008 Center Console w/Ambient Lighting?-100_3101.jpg   2008 Center Console w/Ambient Lighting?-100_3102.jpg   2008 Center Console w/Ambient Lighting?-100_3103.jpg
Old Aug 21, 2007 | 09:12 AM
jacostang's Avatar
Just when you "think" your done messin with your car stuff like this pops up. If it can be done I think this will be an addition!! Keep the info a commin!!
Old Aug 21, 2007 | 10:07 AM
05stangkc's Avatar
we Will Never Be Done Customizing Our Stangs!
Lol,
kc
Old Aug 21, 2007 | 07:03 PM
dmhines's Avatar
Pretty neat if it plugs into the existing harness. So what is the button for .. to change the color?
Old Aug 21, 2007 | 09:20 PM
05stangkc's Avatar
http://forums.bradbarnett.net/showthread.php?t=58602
Original Topic!
Old Aug 22, 2007 | 02:45 PM
frdtch05gt's Avatar
If it plugs in to the original wiring, it should be a simple swap. I guess we will see when parts become available. I'll be following this closely, I want that for my car.
Old Aug 23, 2007 | 01:12 PM
05stangkc's Avatar
I have all the Parts on the way I believe will be Needed to Retrofit the Ambient Lighting Package. So Far it Appears it will be an Easy Install. At this Point it looks like about a $400.00 Investment. I will update after I get the Pieces and do some testing.
KC
Old Aug 23, 2007 | 02:01 PM
2L8IWON's Avatar
Subscribing, you know me Kevin... show me something new and shinny and I am in. Any word on those light up door sill covers?
-Jesse
Old Aug 23, 2007 | 06:00 PM
dmhines's Avatar
KC
Cool ... I don't see where the LED's are from the driver and passenger foot area ... are these not included with the center console?
Old Aug 23, 2007 | 08:38 PM
jacostang's Avatar
Super!!
Old Aug 24, 2007 | 07:22 AM
05stangkc's Avatar
There Are Two LED's Under the Dash at the Outer Edge and Two at the Rear Sides of the Lower Console. I should Have the Parts Today. And Will Post a Pic if time Allows.
Old Aug 24, 2007 | 12:17 PM
jacostang's Avatar
Put me on the list for This upgrade!!!
Old Aug 24, 2007 | 02:26 PM
jim010's Avatar
KC, does this estimate include the centre console base that houses the rear seats LEDs and the front footwell LEDs and brackets?
Cheers
Old Aug 24, 2007 | 04:49 PM
05stangkc's Avatar
Cheers
At this Time it Does But this Is Only if the Upper Console Comes Complete as Bob's Giveaway top is Shown. I thing I just Found another Harness That may be Required Also. I can't tell until Ford Gets Me the Correct parts. When Stuff is this New it is a lot of trial and Error.
Old Aug 24, 2007 | 06:36 PM
frdtch05gt's Avatar
Keep up the good work, we appreciate your effort.
Old Aug 24, 2007 | 06:47 PM
redmsgt's Avatar
Hi KC could you give me the part number for the led light under each side of the dash only. As far as the brackets go there are none as Ford has issued a new dash panel for 08 . The new dash panel has a tab on the under side lip with a hole in it for the lens to pop in. Does the lens have a seperate part # from the led because the lens outline is colour keyed to each trim colour.Thanks.
Old Aug 25, 2007 | 07:43 AM
05stangkc's Avatar
There are a Lot of Hidden Pieces you really have to Dig For. You Will have to Fab a Bracket for the Dash Lights. I am Working on the Lamp Assy. No Part Number Yet. It is Seperate from the LEd itself. Hang tight as I want to present a Couple of Alternatives to the Quote Factory Lamp Layout which may work as well and be more cost effective. Also Since Ford has a Packaging Issue I would Not reccomend anybody just start ordering parts till I get that cleared up.
KC
Old Aug 28, 2007 | 08:46 AM
05stangkc's Avatar
Recieved Confirmation From Ford this Morning, Upper and Lower Consoles Are Mispackaged. It may be awhile Before they Get this Fixed.
Stand By!
KC
