What is the backspacing?
Hi...
I seached for about a hour for the backspacing for upgrade machined cast aluminum wheels for the 2005 GT. I am selling them and someone asked me. I do not know. Can someone help me please?
I have just put on Ford's new 17x8 black bullets with spinners. I will post how the look on a Silver Mustang later. It's now the shop get lowered.
Thank alot,
Brenton
Thank alot,
Brenton
Originally posted by brjohnso281@March 9, 2005, 9:48 PM
Hi...
Thank alot,
Brenton
Hi...
Thank alot,
Brenton
Thanks, Mark.
Mark,
Thanks for the info. I got the 05 .... the dealer charged my 170 each that included the spinners. MSRP $198.57 each
http://www.fordaccessoriesstore.com/fas/co...2839&detail=yes
Thanks,
Brenton
Thanks,
Brenton
Brenton - BS on the 05 wheels is 30 MM. BS on the 04 and below Bullitts & Machs is 45 MM. Did you get the 05 version of the Black Bullitts or 04 version. Just curious, if you got the 05's, how much is Ford charging.
Thanks, Mark.
Are you sure? I think you got that backwards. The offset on the 05 rims is 45mm. Backspacing I believe is 6.25". Offset on the 95-04 depends on what rim you went with. Some were 34mm, 30mm and 24mm. That is why if you put an 04 rim on an 05 it sticks out more because of a smaller offset.
Thanks, Mark.
Originally posted by brjohnso281@March 12, 2005, 6:52 PM
John,
You are correct ... i looked inside the rim and it post there. 17x8 45mm. I should have looked there first. thank you for help....Brenton
John,
Ooops, sorry Brenton, I screwed up :nono: , been quoting those numbers so long I get confused, hope there wasn't any aggravation for you. Thanks for the correction John.
Mark
Originally posted by Original Sin+March 12, 2005, 8:18 PM--><div class='quotetop'>QUOTE(Original Sin @ March 12, 2005, 8:18 PM)</div><div class='quotemain'><!--QuoteBegin-brjohnso281@March 12, 2005, 6:52 PM
John,
John,
Mark
[/b][/quote]
No problem..... no harm...Thanks for the reply, Brenton
Ed M.
05-09 Exterior Modifications
48
Dec 6, 2019 01:24 AM
