Pic of 19" wheels with stock suspension
I want to get a set of 19" wheels and want to see if it will still look good with stock suspension. I will eventually lower my car. If somebody could post a pic that would give me a pretty good idea.
I do not remember the tire sizes.
I sold those rims/tires and used the funds to buy the FRPP SVT version of that wheel in 19" x 9" with a set of 245/45/19" Continental Extreme Contact DW's.
IMHO the FRPP versions are more in keeping with the power level of my NA 07 GT.
The 2011 GT/CS rims have Hankook Ventus 245/45/19" tires.
I am sure that I could have done better performance wise with a different size of tire. But I am old, live in Metro Detroit and I am trying to maximize the sidewall.
I have not driven the car yet with the FRPP rims but I did take a quick photo that should give you some idea of how that tire size looks.
I will be getting the tsw nurburgring in gunmetal black. I want 19x9 all the way around but all of the websites say the widest in the front you can go is 19x8.5. I can't imagine that makes that much of a difference. Also either going with 245/40/19 or 255/40/19 all the way around.
255s all around is good for the Mustang, I wouldn't go narrower personally. I had 255/35-20s in a General UHP that wasn't too grippy but very quiet and comfy.
I really like the 275s, though, amazing grip -- if you like to slide the car a bunch, they're not the best. If you stay at a 35 series (well, for the 20s, it'd be 40 series for 19s, I believe) they're a bit taller overall and give a better ride, at the expense of slightly making the gearing taller.
Just look at the stock size wheels (or the typical aftermarket ones like on TireRack) and see what they use, good starting point.
18 x 9.5 stock GT500 rim has a 45mm offset. 19 x 9 stock front SVTPP wheel has 40mm offset, the 19 x 10 has a 51mm offset. 19 x 10 track pack wheel has 48mm offset.
So generally 40mm or more for a 9 inch wide or larger wheel. Any less (so 24-40mm) will push the outer wheelface closer to the edge of the wheelwell.
http://www.buyfordracing.com/categor...ustang/Wheels/
jim010
31
9/14/15 08:39 PM
