Hood Struts
Has anyone seen or heard of a problem with the CDC or any other hood struts not holding up a fiberglass hood. I just got a Trufiber Venom hood to install on my 2005. A couple of buds of mine are now complaining about some struts NOT holding up their fiberglass hoods well enough. I know mine should be heavier then their's too.
What aftermarket fiberglass hood and who's struts is everyone using? |
You should not use struts with fiberglass hoods. The extra strain put on the structure when you go to shut it tends to crack the fiberglass. That is why the hood manufacturers recommend NOT using hood struts on fiberglass hoods. If you went with an even stronger strut, the effort to close the hood would put even more strain on the structure.
Trufiber uses them on their hoods and advertise as much. I'm going to use them with my Trufiber hood.
-danny |
I have them on my Steeda cowl hood. The support is fine, closing it is effortless. But when closed it causes a bulge along the sides. So I only put them on at shows and cruises.
Originally Posted by Stoenr
(Post 5549787)
I thought I read somewhere that the Trufiber Venom hood has steel reinforcement down the sides and at the latch so it shouldn't bow in the middle.
redline tuning (I think) used to offer a set that mounted way far forward- actually probably get in the way a little, but due to being so far forward they should use much lower gas pressure, as leverage works to their advantage...if anyone knows the ones I'm talking about or where to find them, please speak up :) I just ordered a Fang(aeroform.com) hood/shaker, with the hardware to mount the scoop to the hood instead of the engine(wont shake, but functional and leaves room for a blower) would like to find one of those older style sets...the other thing I liked about them is they push backwards on the hinges, rather than pushing forwards- I think that might help minimize the bulge also...
I HAVE THEM ON MY CERVINI'S HOOD No cracks on top but did notice 2 small stress cracks under the hood near the rear in the paint.
I have cdc on my rufiber gts-2.....No problems whatsoever. no bulging,cracking ..nothing
Originally Posted by pegasusphototx
(Post 5549640)
-danny |
| All times are GMT -6. The time now is 06:00 AM. |
