V6 Sway Bar Nstallation Help
I'm finally got around to adding the rear sway on my V6 Stang and had a few questions...
For those interested, here are the Ford part numbers for the nuts & bolts needed for the rear bar. Qty 4 - W711368-S439 Qty 4 - W520213-S440 Qty 2 - W708737-S439 Qty 2 - W520214-S440 I was going to go with Ford parts, but at around $110 for nuts & bolts, I'm trying to piece with generic stuff. After some digging around I found that needed the Ford Bolts are: 12mm x 65mm (Qty. 2) 10mm x 30mm (Qty. 4) Would these be suitable replacements? BOLTS Class 8.8- M10-1.0 x 30mm (Qty. 4) http://shop.advanceautoparts.com/buy...tml#fragment-1 Class 8.8- M12-1.50 x 65mm (Qty. 2) http://shop.advanceautoparts.com/buy...agment-2<br /> Nuts Autograde Hex Lock Nuts with Nylon Ring-Class 8- Thread Size: M10-1.0, Height: 10mm http://shop.advanceautoparts.com/web...0mm#fragment-2 Autograde Hex Lock Nuts with Nylon Ring-Class 8- Thread Size: M12-1.50, Height: 12mm http://shop.advanceautoparts.com/web...nut#fragment-2 Washers Autograde Mag Wheel Washer 11/16 Inch I.D. 1.2 Inch O.D. 0.14 Inch Thickness http://shop.advanceautoparts.com/web...her#fragment-2 |
