Best way to improve performance
For under 2 grand, what's the best way to get more power out of the six banger? An option I might explore is a CAI/Tuner, but what else is there?
ditch the stock muffler...
while it won't add HP a new set of rear gears will give you an extra kick off the line... might as well throw a LSD in there while you're at it... |
T-lok? What about underdrive pulleys? I'm totally clueless when it comes to gears and pulleys and stuff. What do I need to look for?
I've got Magnaflow Catback dual-exit System on it already |
LSD?? What is that?
Limited Slip Differential :doh:
Go with the tune and CAI, best bang for your buck.
Then I would change the gears out and go with a LSD for more get up and go. Under Drive pulleys is a good add on. Thought about Nitrous? |
dont worry about the udp's its like 5 hp or something
Intake/ tune, exhuast( there no performance gain in duals vs single when mine was s/c i had stock exhaust switched to duals went back got dynoed and 0/0 gain...), and LSDw/ your choice of gears( im an auto and went with 3.73's), thats the most common performance mods a new car will get.... Nitrous-- when the car gets back my zex kit will be removed im gonna be selling it for pretty cheap .. everything i have now is valued over $900 for it... and your in houston im only 3 hrs away so shipping is saved.. cost pm me about it .... also have you checked out the mustangcollective.com all v6 tuners |
T-lok
Originally Posted by paradigm1220
(Post 926484)
