| dhof303 |
Jan 6, 2005 05:11 PM |
After installing the Tri-ax shifter I was excited with the feel of the transmission similar to my Pro 5.0 I had in an 02 GT. What I later found out is that if you do not lubricate the bushings that attach the Tri-ax to the factory shift arm then your shifter will become tight, it will squeak while driving, and it will be difficult to maneuver the lever into the lateral most gears. A marine bearing grade or lithium white grease works great and eliminates all of these problems.
