rear upgrade swap
Old Nov 6, 2007 | 09:12 PM
YaoNYC's Avatar
rear upgrade swap
hi there..
is there a better quality rear (pumpkin) that can be purchased with the correct gears already installed ready to go?
all u got to do is swap the stock pumpkin for this entirely better quality one?
doing this instead of installing 3.55 or 3.73 gears for an auto GT stang.
thanks!
Old Nov 6, 2007 | 10:02 PM
SoundGuyDave's Avatar
Originally Posted by YaoNYC
hi there..
thanks!
You're talking about a carrier-based setup, like the Ford 9" rear end. You'd need to replace the entire housing to convert over, along with all the internals, but if you need to change gears frequently (road course stuff), then it would pay off in terms of time and small parts savings. Once the carrier is set up, it stays that way, and you can swap them out in about 40 minutes, once you get the hang of it.
I remember reading somewhere that Currie Enterprises makes a conversion kit for the S197 chassis, with a new 9" housing, axles, caliper mounts, and welded up with the proper UCA and LCA mounting flanges. It's not particularly cheap, but it is an effective solution for what you're looking for.
Old Nov 7, 2007 | 05:40 AM
YaoNYC's Avatar
thanks soundguydave for this information.
i'll check out currie!
Fords4Ever
Oct 30, 2015 09:07 PM
seaclam
Sep 25, 2015 01:29 PM
M3hunter
Sep 10, 2015 09:26 AM
1001yos
Sep 8, 2015 10:05 PM
Sep 8, 2015 10:45 AM
