-   GT Performance Mods (https://themustangsource.com/forums/f669/)
-   -   OČ sensor delete safe? (https://themustangsource.com/forums/f669/o-sensor-delete-safe-504448/)
paps Jan 25, 2012 01:06 AM
I just installed an O/R jba x-pipe. I got check engine light on (of course no cats!) so my tuner can disable this rear sensor, i would like to know if it s safe to disable it...
rear OČ sensors weren t used to correct air fuel ratio? If disabled, the ecu will not be able to provide right mix?
irishn8 Jan 25, 2012 02:31 AM
Ya, rear O2 sensors aren't needed for a/f mixture. If ur tuner can turn them off then do it. But the front O2 sensors are needed.
Bert Jan 25, 2012 01:52 PM
Here is an article that explains it pretty well:
http://www.tricktuners.com/code_names.htm
In short, like Irish said, you do not need the rear O2's working to get the right A/F mixture, the rear O2's just monitor the cats to make sure they are working . . . which of course they are not in your case
paps Jan 25, 2012 02:11 PM
Thank you guys!
mptant913 Jan 28, 2012 10:05 PM
http://www.bigdaddiesgarage.com/mini-cat-cel-fix.html
Just saw this
paps Jan 29, 2012 02:35 AM
I put a non fouler thing to avoid cel but it doesn t work. I finally removed it with my tuner.
