MGW Shifter - Progressive Springs Install (for beta group only)
This install only applies to the first beta (Group Buy) group only!
As George stated, all shifters with an invoice date of 04/10/07 (and later) will already have the progressive springs installed. Install Progressive springs come pre-greased and ready to install. http://img.photobucket.com/albums/v6...l/IMG_3309.jpg 1. Carefully lift up the shift boot frame until it's free from the center console. http://img.photobucket.com/albums/v6...l/IMG_3313.jpg 2. Using a 3/16" Allen wrench, loosed the 2 cap screws from the shifter block to the central shift rod. Once loose, the whole shift knob, shaft, and boot can be removed. http://img.photobucket.com/albums/v6...l/IMG_3315.jpg http://img.photobucket.com/albums/v6...l/IMG_3317.jpg http://img.photobucket.com/albums/v6...l/IMG_3319.jpg http://img.photobucket.com/albums/v6...l/IMG_3323.jpg 3. Remove center console just like when you installed the shifter. http://img.photobucket.com/albums/v6...l/IMG_3377.jpg 4. Carefully remove the foam pad sound plate. http://img.photobucket.com/albums/v6...l/IMG_3330.jpg http://img.photobucket.com/albums/v6...l/IMG_3333.jpg 5. Carefully remove the rubber dust boot. Once you get one corner up, the rest comes up pretty easily. http://img.photobucket.com/albums/v6...l/IMG_3334.jpg http://img.photobucket.com/albums/v6...l/IMG_3335.jpg 6. Dust boot removed. Take note of the (4) silver 1/4" Allen cap screws. http://img.photobucket.com/albums/v6...l/IMG_3338.jpg 7. Using a 1/4" T-Handle Allen wrench (or an Allen key in a socket), remove the (4) cap screws. If you have neither tools like me, you can just use a standard Allen wrench with a cresent wrench for leverage. Use caution if doing it this way, the Allen can easily slip out from the cresent wrench. Note: If you have the Stop Kit installed, you may have to remove them to access the screws. Note: There are lock washers under the head of each cap screw. Careful not to drop them. http://img.photobucket.com/albums/v6...l/IMG_3341.jpg http://img.photobucket.com/albums/v6...l/IMG_3344.jpg http://img.photobucket.com/albums/v6...l/IMG_3346.jpg http://img.photobucket.com/albums/v6...l/IMG_3347.jpg 8. Carefully lift the top base cap up. There will be (2) springs with cap ends on one end. If one or both fall from the top base, don't worry, just pick them up and set aside. http://img.photobucket.com/albums/v6...l/IMG_3348.jpg http://img.photobucket.com/albums/v6...l/IMG_3349.jpg http://img.photobucket.com/albums/v6...l/IMG_3351.jpg 9. On a work table (or lay out a clean rag), swap the existing spring from the top base with the new progressive spring enclosed in the poly bag. Don't be afraid to get you fingers a little greasy to spread the grease around throughout the spring coils. Note: Ensure that the spring end cap is on top (exposed). http://img.photobucket.com/albums/v6...l/IMG_3355.jpg http://img.photobucket.com/albums/v6...l/IMG_3354.jpg http://img.photobucket.com/albums/v6...l/IMG_3358.jpg 10. Back in the car.. do a little 'safety' check and flip the top over right side up to make sure the 2 springs don't fall out. The grease should keep them in place. http://img.photobucket.com/albums/v6...l/IMG_3362.jpg 11. Carefully position the top base over the shifter shaft and lower down into position. Tip: Move the shifter shaft to the center with your fingers to make positioning the top cap easier. http://img.photobucket.com/albums/v6...l/IMG_3363.jpg 12. Once down and mounting holes aligned, drop all (4) cap screws (make sure you have the lock washers under the head) into the holes and tighten using your fingers to avoid cross-threading. Tighten these screws as tight as they were on using a traditional torque pattern (X or N pattern will suffice). Note: Once tight, pull on the center shaft to make sure the springs are seated and operating smoothly. http://img.photobucket.com/albums/v6...l/IMG_3364.jpg http://img.photobucket.com/albums/v6...l/IMG_3366.jpg 13. Re-install the upper rubber dust boot. Starting at the drivers side corners will make the install easier. http://img.photobucket.com/albums/v6...l/IMG_3368.jpg 14. Re-install the foam sound plate. Just like the first time, start by inserting it through the 2 studs in back and carefully stretch as necessary to get around the shifter base. Once in place, use your method of tucking it under the shifter base. http://img.photobucket.com/albums/v6...l/IMG_3371.jpg http://img.photobucket.com/albums/v6...l/IMG_3372.jpg http://img.photobucket.com/albums/v6...l/IMG_3373.jpg 15. Re-install the center console. http://img.photobucket.com/albums/v6...l/IMG_3375.jpg 16. Position the shift block back over the center shift stud and center the shift knob in the console just as you did when you first installed it. IMPORTANT: Make sure the top of the shift shaft is even with the top of the shift block. Tighten the (2) cap screws down. http://img.photobucket.com/albums/v6...l/IMG_3379.jpg http://img.photobucket.com/albums/v6...l/IMG_3381.jpg 17. Snap shift boot back into the console. http://img.photobucket.com/albums/v6...l/IMG_3383.jpg Installation Complete! Dry run video clip with new progressive springs installed - engine off. http://img.photobucket.com/albums/v6...h_MVI_3384.jpg |
Hey, what's your opinion of them installed? I still haven't received mine....
another great write-up Bill!
although barely a month old.. i hate my steeda tri-ax already anybody up for a swap? :D |
Originally Posted by eci
(Post 898142)
At first, I was more than satisfied with the original springs. But, after trying out the new progressive's, it's just easier engaging the outer gears. To me, I'll take either. Since I went through the install, I'll just leave these in. :grin: |
| All times are GMT -6. The time now is 02:52 AM. |
