I have read most of the related threads, but I had one final question about the install. I have noticed that there is no mention of removing the wheels, so I am assuming it is not necessary. I will try to take before and after photos, as well as measurements.
Well, it wouldn't neccesary, but it would give you more room to work with that's for sure :nice:
I took mine off. I'm not sure it would have been that easy with them on. Plus it gave me a chance to clean the inside of the rims :)
Left mine on, but the swap was done on a lift so they didn't get in the way at all.
Done. Total drop of about 1" and relatively easy as well. I ended up leaving the wheels on.
Are you going to write the step by step? Pics would be good. Also, did you cut or use aftermarket springs?
Darth :jedi: |
| All times are GMT -6. The time now is 07:12 AM. |
