Just to clarify before ordering .... 255/45zr18 front 295/45zr18 rear?
Old Nov 25, 2006 | 09:55 PM
Firedude's Avatar
I have the combo you are looking at and really like it. Over a year with good wear.
Old Nov 25, 2006 | 10:16 PM
06GTwJUICE's Avatar
I made sure the rims i ordered have the correct backspacing, now i just have to get the tires ordered tomorrow for next saturday appt.
I'm stoked.
Old Nov 26, 2006 | 01:14 AM
Realdeal's Avatar
I have that set up. Eibach springs and 255/45/18 and 295/45/18 on 18x9 and 18x10. I got them installed about 3 weeks ago. At first I thought they looked too big but the look is growing on me. The reason I went with this size is almost any other combination the back tire size overall diameter was smaller than stock. The sidewall on the stock 17's is 5" and is only 5.2" on the 295/45's
[ATTACH][ATTACH]Attachment 14520[/ATTACH][/ATTACH]
Attached Thumbnails Just to clarify before ordering .... 255/45zr18 front 295/45zr18 rear?-ctmpphpuxslyz.jpg   Just to clarify before ordering .... 255/45zr18 front 295/45zr18 rear?-ctmpphpnmyyjr.jpg
Old Nov 26, 2006 | 05:47 PM
emperorjordan's Avatar
Originally Posted by SlamMan02
Jordan how do you like the Falken tires?
I love them. They are REALLY sticky dry, and about as good as the stock ones were in the rain. They respond really well to being warmed up. They have ****ty traction when cold.
Old Dec 3, 2006 | 05:47 AM
Redleg's Avatar
Jordan...any more pics of your car? I'm considering the almost the exact same setup except I'm looking at 255/45/R18 in front instead. I'd like to see how this looks from different angles.
You didn't lower your ride, did you? I don't plan on lowering mine...so I think you're as close as I can get to "seeing" what my mod will look like.
Old Dec 3, 2006 | 05:53 AM
Redleg's Avatar
Originally Posted by MTAS
You won't regret the 295/45's in the rear. They will however knock your gear ratio down a notch. My 4.10's are now effectively 3.90's, but it's worth the trade off:
Is your Stang lowered?
Old Dec 3, 2006 | 07:31 PM
06GTwJUICE's Avatar
I'm lowered with the Eibach pro kit.
The rear tires came in and i had them mounted and installed and WOW does she look gooooooooooooooooooooood on those tires!
The tires come all the way to the edge just about and fill the wheel well very nicely.
The front tires are delayed and will be in on tuesday.
I have to adjust the panhard brace to get the rear centered again it's off to the left about an inch.
Car hooks much better in second, less wheel spin....
Old Dec 4, 2006 | 04:43 AM
MTAS's Avatar
Yep, Eibach Pro all around.
Old Dec 4, 2006 | 06:41 AM
Redleg's Avatar
At first I was planning on doing the same tire setup without the drop...your pics make me reconsider. What type of rims are those by the way?
Old Dec 4, 2006 | 07:11 AM
34124231user's Avatar
Originally Posted by mikeelia
I like the look of the Bullits, and I decided to keep the front tires and wheels so I got the mustangtuning 18x10 bullit knockoffs for the rear so I could add a wider tire with basically the same diameter and matching Pirelli Pzero nero tires.
So, I have the Steeda Sport springs with adjustable front camber plates with the stock tires and wheels up front and the Pirelli 285/40Z 18s in back.
I haven't decided yet whether I want to go to the 18x9s up front [I hate to add MORE weight or mess with the steering].
Mike E
Mike-
I have been considering doing the same thing with my car- keeping the stock front bullitts (I really like the bullitts) and going with the 18" bullitt rears. Does the paint match the front wheels on the FRPP 18" bullitts? The stock wheels are listed as anthracite, and I think FRPP lists theirs as silver. Or are your rear wheels not FRPP?
Thanks for the info.
Old Dec 4, 2006 | 03:02 PM
I am lowered with the BMR lowering springs. You should look at S197GTs car... he has the same wheels as me (but in black) and he isnt lowered.
Old Dec 4, 2006 | 03:15 PM
S197 GT's Avatar
3rd Times A Charm
You rang...
Old Dec 4, 2006 | 04:20 PM
SlamMan02's Avatar
S197- Looks awesome!!
Old Dec 4, 2006 | 05:48 PM
Redleg's Avatar
Nice....tough decision. I need to see what 295/45s look like on the rear without a lowering. Anybody?
Old Dec 4, 2006 | 06:36 PM
Hatchman's Avatar
I have never seen a pic with a S197 with 295/45/18's on the back and not lowered, but I'm sure there are some out there.
Personally, I'm thinking about the Falken RT-615 w/ 255/45 and 295/40 on CT-r 18x9" and 10"s.
Old Dec 4, 2006 | 07:04 PM
tmf's Avatar
tmf
That is the look I'm going for on my GT/CS. What are the specs for the rims front and back and what backspacing did they have?
Thanks in advance!
john
Old Dec 4, 2006 | 08:37 PM
Redleg's Avatar
Using the calculator here....
http://www.bigcustomwheels.com/rt_specs.jsp
The 295/45/18 is 1.3 inches taller than the stock 235/55/17 tire. Am I correct in assuming that the 1.3 inch height increase will fill the gap between tire and fender?
I don't want to stuff the tires in there necessary will a big drop.
Old Dec 4, 2006 | 10:35 PM
AFBLUE's Avatar
Dethroned Nascar Guru
I believe that a 1.3" taller tire will fill the gap by half that amount (i.e. .65"). If so, then it also results in a .65" higher ride height.
Old Dec 5, 2006 | 04:47 AM
MTAS's Avatar
Thanks in advance!
john
Front: http://www.americanmuscle.com/verde-...heel-18x9.html
Rear:
http://www.americanmuscle.com/anthra...8x9-18x10.html
Old Dec 5, 2006 | 05:35 AM
  #40
Redleg's Avatar
Thanks for the link....the rims in your attached pics look a different color than the anthracite rims on the AmericanMuscle site. I actually like yours better and am glad they are colored that way.
