-   GT Performance Mods (https://themustangsource.com/forums/f669/)
-   -   The GT Performance Timeslip Thread (https://themustangsource.com/forums/f669/gt-performance-timeslip-thread-432764/)
MCTUNGSTEN Jul 15, 2011 11:35 AM
See time in sig. below. I need to do better........:banghead:
andystrucking Jul 30, 2011 09:55 PM
1/8 mile
2.0901 60'
5.7690 330'
8.8268 660'
81.10 mph
2008 gt 5 speed ford racing cai with ford racing pro cal tune pypes axle back violator's 4:10 gears relocated rear lca's 2.5 inches street tires (not drag radials) removed drivers front sway bar link rear tires at 25 psi
let me update for this week, was a little cooler out. approx 75 degrees. lost first round because of .4932 red light.
2.0486 60'
5.7118 330'
8.7398 660'
82.13 mph
JWT06GT Sep 11, 2011 10:20 PM
06 GT 5spees
1/8 th
.1137 reaction
2.04 60ft
5.63 330ft
8.55 1/8
84.43 mph
Running on 20s with 255/35/20 on front and 285/30/20 on rear
trucker Sep 17, 2011 05:18 PM
won't be going out to the strip for atleast a month
have to break in my new engine first and touch up the tune
left the bottm end and bore kinda stock mahle pistons scat rods eagle crank
going to bump the boost up to 12lbs. and then go see if I get kicked off the track
cause I don't have roll bars I will post when I go out
tigerhonaker Nov 2, 2011 08:14 AM
It would take way to much room here to List all the Mods/changes.
So instead here is the on going build Thread.
http://www.imboc.com/forums/showthread.php?t=176176
http://i258.photobucket.com/albums/h...cwithSpecs.jpg
http://i258.photobucket.com/albums/h...Slip1032-1.jpg
tigerhonaker
69Mach1-409 Nov 14, 2011 07:36 AM
New PB at the 10th Annual Andrew Bauer Memorial Nats at Cecil County Drags.
Car 107
http://a2.sphotos.ak.fbcdn.net/hphot...23474444_n.jpg
RT- .094
60'- 1.661
1/8 ET- 7.427
1/8 MPH- 96.14
1/4 ET- 11.543
1/4 MPH- 120.78
-281ci (stock)
-TR3650 (stock)
-3.55 (stock)
-2.3L Whipple @ 10lbs
-stock clutch
-275/40/R17 M/T ET Street Radials
lindertw Dec 14, 2013 05:45 PM
N/A 3v, 302 rwph / 317 rwtq
- CAI / Steeda UDP's / FRPP shorty headers
- Strange single adj struts/shocks
- Cobra Jet springs
- Detroit Truetrac diff / 4.10 gears / LPW diff cover
- Metro UCA/UCA bracket and LCA's
- BMR relocation brackets
- M/T ET street bias ply rear tires on 17" OEM rims
- OEM stock shifter / clutch / 2pc drive shaft / intake manifold / cams / etc.
I'm still dialing in strut/shock/tire pressure settings. Plan to get a set of skinny front wheels/tires this winter and shed a bit of weight for the spring. Working on driver mod too (this was my first year of racing).
http://i910.photobucket.com/albums/a...ps121af0bb.jpg
http://i910.photobucket.com/albums/a...ps058fdb75.jpg
http://i910.photobucket.com/albums/a...ps0323d6d9.jpg
http://i910.photobucket.com/albums/a...pscca923ef.jpg
winter mods:
- 15" front skinnies
- lightweight drivers seat for track days
- install shift light
shooting for 12.1x's in the spring...
ElkGroveFordGuy Apr 17, 2014 12:02 AM
This was my first time to the drag strip with this car all stock except for a set of GT500 mufflers!
Best run of 13.02 at 110.4 mph!
I was really hoping to hit the 12 second mark but fell a little short.
I was very impressed with the trap speeds out of this car stock.
110+ MPH that's fast!
But I was crossing the finish line in 4th gear @ 6700+ rpm and bouncing off the rev limiter as I was crossing the line.
My 60 ft time were horrible @ 2.21 no one on street tires were much better!
ElkGroveFordGuy Apr 17, 2014 12:05 PM
Does anyone know how much of a difference the procal gunner will make in 1/4 mi. Performance.
I'm putting mine on next week!
fdjizm Apr 17, 2014 01:59 PM
Not bad man, keep it up.
Procal tuner? if so I think you should go SCT on the tuner, much more options for tunes with greater gains than what ford supplies.
ElkGroveFordGuy Apr 17, 2014 02:34 PM
I already have the procal, plus I work as a service writer at japan brand X, and friends @ the local ford dealers have told me about several occasions that people have had there warranty claims denied on motor issues because of having an aftermarket tune, ( in most cases the tunes probably did not cause the problem but were the cause of warranty claim denials) with the procal tune I still maintain a warranty! Plus I'm not looking to go all out just get a little more power and better throttle response which the procal should give me!
After talking to several people at the track last night it seemed every one was running .2 - .35 slower than normal because the track was not really prepped at all! So I could have easily broke into the 12s if the track would have been preped!
lindertw Oct 31, 2014 02:57 PM
1 Attachment(s)
24OCT14 midnight madness/test and tune @ MIR
http://i910.photobucket.com/albums/a...ps7ebdc2a7.jpg
3490 lbs race weight with driver, helmet, 1/8 tank of gas, gutted trunk, pass seat and rear seat back/bottom removed (3265 lbs w/o driver and helmet)
pb 60 = 1.611; 1/8 = 7.819; 1/4 = 12.339 DA was between +99 ft and -299 ft throughout my runs per drag times calculator
http://i910.photobucket.com/albums/a...psa7a92741.jpg
Attachment 190513
Spun bad on the third pass after following several street cars that drove through the water box
I missed 2nd gear on the last pass, it may have bested my 12.339... There's still some tweaking to do with tire pressure and shock/strut settings. I may have a high 1.5x 60' left in the car, and maybe 12.2x ET by years end.
tbear853 Dec 31, 2020 09:56 AM
Have not run our '08 GT 5 speed with 3.31 rear on a strip, but back in the mid '70s I did play some at New London Dragstrip near Lynchburg, I worked there too. I was looking through some old papers in a small wooden box, found some time slips from the '70s in there, with notes I made at the time.
I had a '73 Mustang Grande with 302, 2bbl, C-4 automatic, 3.00 rear, dual exhaust with Walker replacement Mach 1 mufflers (it was quiet, but I only did it for looks, V8 need duals) run:
19.69 sec quarter @ 67 mph
Was one really hot day, I see I noted with AC on just looking at the slip.
It was "bracket racing", I think I won and lost in the next round when I broke out with a sub 18 sec run ... it hooked better maybe, and I likely turned the AC off that run, my FUBAR.
Just to add, I did get a 13.01 at 104 mph in my '69 Dodge Dart Swinger 340, 4 speed, 3.91 open rear on recap tires, but I had monkeyed with the pinion snubber height and left - right rear shock bias. I noted on that time slip that I edged out my buddy's '70 'Cuda 440-6pack 4 speed with 3.54 posi on that run, but he wasn't as good at driving as he thought. The 340 did have an Ededlbrock LD 340 intake and Holley 3310 780cfm carb but was otherwise bone stock then. Cam, headers, ignition all came later. My buddy's younger brother still has the 'Cuda. I wish I had the Swinger. I also broke out once in bracket racing on a 14.10 dial in in my '65 GTO 4 spd with 4.10s on street tires, I was really trying to go easy on it, granny shifting, etc, run a 13.66 by mistake and the cam gear came loose in top of 4th and it bent 4 intake and 4 exhaust valves. It had a '69 400 RA we put in there to replace a tired & very loose 389. Muncie 4 spd was a 2.54 low M-21 and rear was a 12 bolt from a Chevelle at a bone yard.
Mustang Freak Dec 31, 2020 10:58 PM
Nice story! :yup:
PaulHong Jun 23, 2023 01:47 AM
Thank you for sharing the timeslips for different modifications on S197 GTs.
