380 miles on GT, the service engine light came on
Old Sep 13, 2005 | 10:08 PM
1 COBRA's Avatar
I am using 93 octane and have Flowmasters axle-back. Could either one be the cause? I have used 93 octane and had aftermarket catbacks on previous GTs and Mach 1 without any problems.
TIA.
Old Sep 13, 2005 | 10:11 PM
Dan's Avatar
Dan
Do You Remember Me?
TIA.
Don't remember anyone saying they had issues with the Flowmasters and the CEL.
Why are you running 93 octane? The brochure says 87 is just fine
Burn a tank, switch the gas and see if it goes out. You may want to reset the computer to clear the code.
Old Sep 13, 2005 | 10:17 PM
wild stray's Avatar
93 & Flows won't cause a CEL. Check to make sure your gas cap it on tight.
Paul
Old Sep 13, 2005 | 10:30 PM
Dan's Avatar
Dan
Do You Remember Me?
Also some TSB's which may help....
04-26-22
MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH MULTIPLE DIAGNOSTIC TROUBLE CODES (DTCS) P035X AND NO DRIVEABILITY SYMPTOMS - 4.6L 3V ENGINE
04-16-1
ENGINE MISFIRE OR ROUGH RUNNING - COIL ON PLUG (COP) IGNITION SYSTEMS - WDS COP KIT DIAGNOSTIC TIPS
Also, a post on the CEL said they were experiencing rough running because of a cracked plug, coil over needed replacing....
Old Sep 14, 2005 | 07:13 AM
mlcrisis's Avatar
Have you over filled the gas tank by any chance ??
I did once, trying to put as much gas in as possible and to get the $$ at a even # on the pump. In doing so, I over filled the tank and some gas ran out.
When I cranked up to leave the station, the CEL light was on. I thought crap whats up with this. Took it to the dealer the next day & told them what happened. They said it happens fairly often, nothing wrong, that the CEL light will go out when it gets to 1/4 tank of gas. They didn't even check the car. Sure enough, at 1/4 tank, the light went out.
Old Sep 14, 2005 | 07:25 AM
MaverickMLFD371's Avatar
I too have the Flowmasters and 93 Octane, no problems here.
Old Sep 14, 2005 | 12:52 PM
softbatch's Avatar
I talk to cones.
Ive been using 93 Octane on the stock tune for 2k miles and have had no cels
Old Sep 14, 2005 | 07:25 PM
1 COBRA's Avatar
The error code turned out to be the sensor for the fuel tank which sets off the check enging light for the gas tank being too low or too full.
In this case it was too full. My bad. The pump keep stopping and I kept pumping fuel all the way to the top. This has been my habit with all my previous Mustangs. I'll just have to be more careful.
Old Sep 20, 2005 | 12:18 PM
KWMJ-KTP's Avatar
That's kind of odd. I always top off my tanks and have never had this issue. However, now I may be cursed to experience it now that I have read about it. But at least I'll know whats going on I guess.
Old Sep 21, 2005 | 12:16 PM
Indystang's Avatar
I always top mine off too and never got the light. I dont think I would run 93 octane fuel without getting a tune. I heard high octane fuel burns slower than 87 and can cause other undesirable codes. You might want to check up on it some more though. Good luck!
Old Sep 22, 2005 | 06:57 AM
Hatchman's Avatar
I top off all the time and no codes... mmm...
Ecostang
Nov 3, 2022 08:50 PM
jc46002003
Apr 15, 2016 03:00 PM
ssjbuu
Aug 28, 2015 08:55 AM
Will3212
Jul 16, 2015 10:30 AM
