05-09 Shifter Experiment Fab WORKS!
Hey all.
I completed my Automatic Shifter Build experiment and it works perfectly. Rather than going with the seemingly only other option of the TCI Rachet Shifter, I fabricated my own Ball Shifter because I don't like the look of the big "T" style Shifters. I working used a White Madness Ball Shifter for a 2010-2014. I bored it out to fit the 2005-2009 Shifter Post. It looks more like a Manual Ball Shifter, but works as the normal Automatic Shifter. I connected the Overdrive Button separately to 12mm DC Power Button 5V LED, Waterproof Latching Push Button Switch On/Off 23V (Red 2V). I drilled a hole and dropped it into the Button Switch in console to the right of the shifter. I set it for the LED to be on when overdrive is off. Let me know your thoughts.https://cimg2.ibsrv.net/gimg/themust...5689bf5256.jpg https://cimg5.ibsrv.net/gimg/themust...95b8c70bd3.jpg https://cimg8.ibsrv.net/gimg/themust...d92b48f4b0.jpg |
Hey there, new member here. I've been looking for ways to come up with this same solution for my 2006 automatic. Do you have any pics of the install process? The shifter shaft is such a large plastic square - I didn't realize there was enough room in the White Madness Garage knob to bore it out for that. Thanks!
Hey.
Thanks for the feedback. Sorry, I didn't think at the time to take pics as I went through the installation and fabrication. |
Totally understand, thanks anyway. Looks fantastic.
My shifter doesn't have the plastic block at the bottom of the shifter, but the shifter knob will still fit on the upper part of the shifter. It will just sit an inch higher.
When you say the block, do you mean the cover with the PRND321? I figured it would work best with that removed. I did get a trim ring and boot from a 5-speed car, so I figured what's the point of leaving that PRNDL cover on. I was more concerned about the thickness of the plastic stump, once the T-handle/cover is removed... I wasn't sure (from pictures) that the WM shifter had enough aluminum to be able to bore it out enough. I ordered it, so I'll see it first-hand. I stumbled onto this idea because I picked up a really clean console from a 2009 Bullitt, mainly because it still had all the factory ambient lighting components... they left the boot and knob on it and I thought, wait a minute - this could almost work. Finally searched "home made shifter handle for 05-09 Mustang" and stumbled onto your post.
Originally Posted by aborick
(Post 7085062)
Hey all.
My shifter did not have the plastic at the bottom of the shifter shaft.
Mine looked like this. https://cimg9.ibsrv.net/gimg/themust...044ced6151.jpg |
Gotcha. That appears to be a 2010-2014 shifter. So did you change that at some point, or was it in the car when you bought it?
This is a stock 2005-2009 shifter, which is what I have: https://cimg2.ibsrv.net/gimg/themust...fe7eba5078.jpg |
Interesting.
I bought the car 6 years ago and it was this way. |
(Post 7085103)
Originally Posted by jallen670
(Post 7085105)
(Post 7085106)
Interesting.
You were an inspiration, aborick. Installed a 2010 shifter with White Madness ball in my 2006 automatic. Swapped in a console from a 2009 Bullitt with ambient lighting while I had the old console out, because why not.
https://cimg0.ibsrv.net/gimg/themust...02d24a93a.jpeg https://cimg0.ibsrv.net/gimg/themust...b488db9b4.jpeg |
:nice:
Very Cool! Looks Great! KC Have You Considered an Electronic Gear Indicator?? https://www.google.com/search?client...gear+indicator I Really Something Like This Would Be Cool! https://www.summitracing.com/parts/l...iABEgIxrPD_BwE |
(Post 7085477)
:nice:
Very Cool! Looks Great! KC Have You Considered an Electronic Gear Indicator?? https://www.google.com/search?client...gear+indicator I Really Something Like This Would Be Cool! https://www.summitracing.com/parts/l...iABEgIxrPD_BwE Thanks for that, KC - I think something like that could be a slick solution. I had considered making a custom plate for inside the bezel, as that’s just a Bullitt boot and bezel flipped 180 degrees, so the boot slack is on the side that needs it - it is still very tight, though. Maybe a combination of some kind of aluminum plate with a small indicator mounted in it? I see more internet research in my future… |
You Are Welcome!
I Thought About a Mechanical Solution as Well. Simply a Pointer in a Slot With Some Nice Lettered Font Next to it. Whatever You Come Up With It Would Be great To See Some How To Pics For The Viewing Audience! Some Good Research Would Be Looking at Factory Floor Shifts Over the Years and See How The Factory Had it Set Up. What Would Be Way Cool is Somehow Adapting The Guts Out of An Earlier Mustang Bezel. Just a Thought! Just Spitballing To Get You Thinking! Another Good Place to Look For Idea's Would Be at a Street Rod Show As a Lot of Those Cars Had Transplanted Shifters & The Like! Best of Luck & We Look Forward To Your Solution! Kc |
(Post 7085476)
(Post 7085477)
:nice:
(Post 7085483)
I stand corrected on something I posted early in this thread. Rick’s 2005’s shifter is likely original and not swapped out by the previous owner. I now understand why he noted boring out the White Madness shifter to fit the larger diameter post. I dissected my 2006 shifter and found it does not match the pic I re-posted of the square plastic stump. It would appear early S197s likely had a different design where the plastic block was part of the T-handle (Pic 1). Mine is an early 2006 (mfg 8/05), so there had to be a revision sometime after that. This earlier design, it’s worth noting, is a 2-piece design, where the linkage bracket is stamped steel and is screwed onto the plastic body of the shifter (Pic 2). On mine, this screw had backed out several threads, which probably explains the sloppiness I was feeling. I was attributing this to the mostly plastic design, but that’s probably not the case, as the 2010 has even more plastic, though with its one-piece design, the linkage bracket is part of the main housing. Anyway, for Rick, or anyone who still has this original design on their car, it’d be worth checking that screw if your shifter action is feeling spongy (Pic 3).
Pic 1: https://cimg7.ibsrv.net/gimg/themust...acfcdb972.jpeg Pic 2: https://cimg2.ibsrv.net/gimg/themust...ede518767.jpeg Pic 3: https://cimg8.ibsrv.net/gimg/themust...8ba03d3be.jpeg |
FYI, That is The Early Style and You Could Swap The Black Handle For The Silver One on The Early Cars. Be Advised The Later Ones Don't Like To Go Back Together if You Pop The Knob Off. There are a Couple of Threads in Here Where This Has Happened!
The Earlier Style Was More Durable Except For The Accordian Slide Insert Getting Jammed Up! Here We Go! https://themustangsource.com/forums/...ussion-549852/ KC |
(Post 7085476)
(Post 7085492)
Pic 1: https://cimg7.ibsrv.net/gimg/themust...acfcdb972.jpeg Pic 2: https://cimg2.ibsrv.net/gimg/themust...ede518767.jpeg Pic 3: https://cimg8.ibsrv.net/gimg/themust...8ba03d3be.jpeg I checked the bolt and added a little locktite just in case. |
