Tires for Track Days
Received 1,498 Likes
This shouldn't be such a hard decision! LOL
275/35 is the size I would go with on a 19x9.5. If you're wanting a lot of street use something like the MPSS is probably a safe bet, 200 or lower treadwear tires are hard to judge for that
Decision time is here on tires! Any new thoughts or suggestions?
What I'd really like to find, is some RE-71R's for about $200 each . . . ;-)
yeah, and you mentioned that at the time, and I snoozed on it, and by the time I woke up they were gone! wishing I had grabbed a set of those . . .
right now I am thinking I will bite the bullitt and shell out the $1,300 for a set of RE-71R's, at least it's cheaper than a new car right?
I missed the close out on the RS-3's as well, but I did get a set of the Nexen NFERA SUR4's on closeout last fall for around $200 each in 275 35 19. I just got them mounted on a set of new Apex Racing 19 x 10" wheels last weekend. I can't wait for it to warm up a little more so I can bolt them on.
One note:
Remember to heat cycle your new tires guys. My first event I was loose and sliding all over the place. Second event they were hooked up. They will need to cool off over night to set. I thought maybe letting it cool off for 2 hours over lunch would do the trick, but I've never been more sideways at the track than that afternoon. It took over night as advertised.
I was wondering the same thing. I doubt it . . . maybe on an open road at 4 AM or something, with a lot of swerving and hard braking?
The Advancetrack issues still persist, huh? Not good. Can you switch it to Advancetrack off and use ABS only setting? Or is that issue also messing with ABS?
That's what I do, 7 second hold at standstill with brakes on. You risk loosing it, but no better way to learn limit handling than switching it all off and slowly working your way up in speed. This way you learn to anticipate the oversteer/understeer and the correction required.
In this video right around 5:50 I had to make a huge correction (greasy not heat cycled tires). I think the only reason I was able to save it was a lot of time with system off
I have done a bit of research into heat cycling tires. Tire Rack will heat cycle them in some kind of oven before sending them to you for $15 per tire. The interesting thing is they say that it is only necessary on race compound tires. They do not recommend the service for 200 tread wear tires like the RS-3's or Nexen NFERA SURG's. They say there is really no benefit to heat cycling a 200 tread wear tire.
That kinda makes sense though. For slicks (40 thread wear) is a must. With 200 thread wear tire you won't notice the difference on the street. But they will be noticeably sticker on your second track day than on the first. Just something to keep in mind I guess.
It used to only happen on the track, but last fall I had it happen on the street a couple times. I did get a new clue recently that it might actually be caused by one of the wires hitting the exhaust, but haven't gotten under there yet to follow the wire and see if that is the problem.
I haven't watched the video yet because I am at work, will enjoy that some evening with speakers soon!
Meanwhile I keep second-guessing myself about the tires; now thinking the MPSS might be the best compromise . . . and there is snow on the ground and more in the forecast, so I still have some time.
Currently a Corvette Owner!
Side note...I do track days with S550 guys, and they can change drive modes on the fly, while us S197 guys have to stop, foot on the brake, then tap the button...UGH
good point, if you forget to switch it off before getting on track then all you can do is double tap for sport mode. Unless you come in and miss out a lap. Would be nice to just be able to enter all the modes while in motion
For sale: $1600 wheel/tire package. Used Forgestar F14 18x10 +42 w/mounted/balanced new Hankook RS4 285/35-18 square setup. Tires bought for MVP Tracktime at Daytona December 2017 but event was cancelled (zero trackdays use) message me
#40
Hi 5.monster, after the radiator change, grill change, oil cooler install, water wetter & DI water, and finally removing the AC condenser I finally conquered my overheating demons lol. My last trackdays we're Mosport and Lime Rock last year, MVP Tracktime cancelled last minute in Dec 2017.
I actually recently traded the Stang and got a 2018 ss 1le Camaro, which I never though I'd say. I'm still learning about the car but being in a 1le track FB group and forum pages starting to change it towards corner carving. I am finding out I'm not having to do much since technology has come a long way since my 2011 Mustang :-) lol
