Waterspot stains
Old Jul 30, 2005 | 06:54 PM
KansasCityTim's Avatar
So, I washed Scarlett today in the 95 degree heat, and I went inside to cool down for a bit. needless to say, I had a lot of waterspots. So, I got out the Z-6 and wiped it down. Amazingly, some of the little buggers didn't want to come up. If I polish on them really hard, they come up, but is there anything easier? Will they come off the next time I wash the car? I have never not dried my car immediately after washing it, but I felt a little dizzy today, so I went into the AC and sat down a bit. I am just shocked at how much water seems to stain the finish!
Old Jul 30, 2005 | 07:01 PM
ToothlessJoe's Avatar
White vinegar will get them off if they arent too baked in. I keep some in a spray bottle.
The one thing that will reliably get them up is a clay bar. But this will strip off the wax too.
Old Jul 30, 2005 | 07:04 PM
Boltzman's Avatar
The only thing I can tell you is put the elbow grease to it..I have never seen anything work easy for water spots.Did you wash in direct sunlite?/I live in Fl. and it is a cardinal sin to wash in this sunlite..My advice is to wait till about 1 1/2 hrs till sunset to do it..don't kill yourself in this heat!!Dry immediately(or use your leaf blower,it's actually fun!)
Old Jul 30, 2005 | 07:59 PM
Boomer's Avatar
Claybar as stated
Old Jul 30, 2005 | 08:10 PM
I have only used a claybar once, but I am getting the impression that if an clayba doesn't get it out, nothing will.
Old Jul 30, 2005 | 09:42 PM
DanteMO's Avatar
I think the vinegar trick will work...If not, you can pick up some polish (NOT RUBBING COMPOUND) like Klasse and that should do the trick.
Old Jul 30, 2005 | 10:00 PM
ManEHawke's Avatar
Slight damp non arasive cloth will do the trick. Minimal elbow grease required.
Old Jul 30, 2005 | 11:22 PM
AJC's Avatar
AJC
Mothers gold showtime instant detailer.
I get water spots every time I wash - due to the water here. This stuff removes them easily
Meguires NXT Speed Detailer spray also does great.
Old Jul 31, 2005 | 12:29 AM
What about if they have been dried for awhile?
Old Jul 31, 2005 | 04:22 AM
Dusty1's Avatar
I use a California Water Blade to "squeegee" off the standing water before it dries. Anything left gets the chamois.
Old Jul 31, 2005 | 04:25 AM
ponyboy66's Avatar
The spots will come off the next time you wash the car provided that you use a good wash solution.
I have been using the Meguiars NXT car wash.
It is formulated to emulsify dirt and grime and water spots. The key is to not wash/dry in direct sun light.
Old Jul 31, 2005 | 06:09 AM
nynvolt's Avatar
I just wipe them with a damp cloth or chamois and then wipe dry with a micro fiber, seems to work just fine. never had a waterspot that required clay bar, thats gotta be some hard water :shock:
Old Jul 31, 2005 | 07:16 AM
adrenalin's Avatar
The vinegar idea should would. Just remember, never wash you car in the sun on a hot day.
Old Jul 31, 2005 | 08:02 AM
harleybill's Avatar
I basically use glass cleaner with a nice soft cloth if I find any residual spots that I may have missed. Of course, do it in the shade and after the metal has cooled. Use the california wiper. It does wonders and takes only a few minutes.
Old Jul 31, 2005 | 08:15 AM
jwgroovin's Avatar
Exactly what I do, about 7:30pm eastern. The sun is going down, the temp has dropped a bit...
Old Jul 31, 2005 | 11:12 PM
AJC's Avatar
AJC
They have dried by the time I get to the detailing spray- I have a Black stang, so water spots are my nightmare...
It works everytime. I also wash the car towards the evening and pull it into my garage to dry it.
But no matter how fast i try to dry the car in the shade - I always end up with hard water spots dried on by the time Im done, the two products I mentioned get them off.
Old Aug 1, 2005 | 05:41 AM
sams66's Avatar
Vinegar has worked for me, also the clay bar.
Sam
Old Aug 1, 2005 | 05:49 AM
Qrazy's Avatar
Call Sal....If you are using Z6 you know who I mean
Old Aug 1, 2005 | 06:16 AM
Blk'05's Avatar
You felt dizzy from the heat then you went into the a/c :nono:
Old Aug 1, 2005 | 06:20 AM
tw0scoops123's Avatar
You shouldn't wash a car in 95 degree heat. 2 seconds after you spray water on the sizzling metal body, you'll start get water spots. Wait until it cools down outside or the sun goes down.
