Buffer
Since everyone else is by far more experienced at detailing, I thought I'd ask. I'm asking what the best buffer for a home user is? I have several injuries from previous stuff and when I try to detail, I'm usually down the next day due to pain. I have a cheap orbital buffer from the local auto store, but I ended up wiping the entire care anyway cause it just didn't see, to do the job. If I could get a good buffer, it may make the job a lot easier.
Also, I inadvertently got minor wax on some of the trim, what's the best way to get that off as it's now grayed some of my trim?
There are many detailers far more experienced and skilled than myself on this site. Hopefully they'll chime in too.
As for myself I recently purchased the Porter Cable 7424xp. Polished and waxed the car with it once so far. Works as expected. Nice speed selector.
I've seen pencil erasers used to get old wax off of plastic trim in the past.
Good luck.
Good luck.
Just Plain Rude!
I can't help ya as far as the buffer goes. But for getting the old wax off of plastic trim, I've used Meguiar's interior quick detailer...I think that's the one I used. There's plenty of products for use on plastic. I'm sure any of them would work just fine for getting the wax off.
Good luck.
Just Plain Rude!
Depending on how long it's been on there, you might have to do some scrubbing. I'd think erasers would work too (although I've never done it). They might leave eraser marks, so a plastic detailer would still be handy to have.
My husband bought that too! I used it on my vert and it works great! My husband used to detail cars, tried to start his own business but he got sick and it didn't work out as planned.
I hope your husband is doing better health-wise. Best wishes.
Isopropyl alcohol will remove wax on the trim. Dip an old toothbrsuh it it and gently scrub, then wipe dry with an older microfiber towel.
The next time you polish and wax the car, tape off the trim with 3M painters tape beforehand. It keeps the polish and wax off the trim and makes cleanup a lot easier.
Originally Posted by DaGonz
The buffer you want is the Porter Cable 7424xp, then go to a website like Autogeek and order pads for cutting, polishing and finishing.
I'm currently using the McGuires Ultimate which seems to do a sufficient job. I didn't detect any swirls or streaks with it after a thorough wipe down. Of course the trim mistakes showed up after being in the sun.
I currently have a 7424xp, but I've also heard very good things about the Griot's DA polisher. Seems to be more popular with pro detailers than the 7424, and it costs a bit less.
Thanks Overboost! Just looked that one up and you're right - it actually has a stronger motor and weighs les than the 7424. They have several kits for the DA on autogeek ( http://www.autogeek.net/griots-garag...sher-club.html ) which includes a 3 1/2" buffer for small areas! Might seriously look at that one or one of the other kits.
