Weird issue at idle
Weird issue at idle
I have a 2005 Mustang V6 and lately I have noticed that when I am idling at a stoplight, about once every 60secs the rpm's will drop by a few hundred.
Its just for a sec or 2 then goes back to normal rpm.
I was working on it this morning and noticed that when the rpm's drop like that, its the same time that the electric fan kicks in at the radiator.
I hooked up my code reader and can see that when the ECT temp hits 95degrees, it starts the fan up. I am guessing the fan is failing and drawing too many amps.
The battery and alternator is brand new so I dont think the issue is with that.
Is this an indication that the fan is about to fail? its still the original fan the car came with.
The car never stalls out, just feels like its going to. When it happens I usually pump the gas to get the rpm's back up lol
Any advice would be greatly appreciated
Welcome,
Have You Cleaned MAF & T/B Recently? If Not I Would Clean Both With Proper Chemicals T/B Cleaner & MAF Cleaner & Then Disconnect Battery To Reset PCM & Drive For a Couple of Days To Complete a Drive Cycle & See if That Helps. Also I Would Pull Connector at Cooling Fan & Look For Signs of Overheating Wiring & Poor Connections Clean With Electric Contact Cleaner.
Also A good Time To Add Some Good Fuel Cleaner To Fuel System. Ford Loves To ADVISE Techron Additive!
A Good Start I Think. I Guess You Are Not getting Any Codes. You Might Also Let Car Warm Up & Watch For The 95 Degree Mark When Idle Drops & See if A/C Compressor is Cycling at Same Time Causing a Load & Bringing Idle Down. The Cleaning I Advised May Help Engine Respond To Load Quicker Regardless!
Anyhoo, That is What Pops To Mind.
Kc
Kc
coastalS197
Jul 21, 2011 07:16 PM
