Need advice from the old suspension guys.
Hey kids, got a question. I want to get the "jackrabbit" stance out of my '07, but I'd rather not lower the entire car. Will a set of rear lowering srpings level the car up, and drop the rear end like were are still in the mid 1960's. Something like these.
https://www.americanmuscle.com/bmr-m...ed-sp067r.html https://cimg7.ibsrv.net/gimg/themust...6b052f372f.jpg Thanks for the help guys. |
Ok, Here is Something to Consider. First Thing Get a Full Tank of Gas! Now Do You Ride Solo Most of The Time or With a Passenger? Do You Ever Pack a Trunk Load & Go Traveling in the Car. If So You May Want to Load Car With The Norm & Then Look At The Ride Height. Don't Want to Be Draggin The Rear! I Like The Roush Stuff as I Used To Sell it and Have Good Luck. Looks Like a Half an Inch With These But A Call To American Muscle Can Verify. Other Than That Perhaps We Have Someone With Actual Hands on With Your Scenario That Can Chime in!
https://www.americanmuscle.com/roush...s-0514-gt.html KC |
Back In The Day The BULLITT Springs Were Considered The Hot Setup!
Some Wise Guy Got FORD to Cough Up a Spring Rate Chart. This Was CORPORATE Info not in Parts or Service Catalogs! :hmm: Here is a Side View Don't Know if I See it Being Much Lower But Interesting! Hard To Judge With a Dark Car Unless Pic is Just Right! https://themustangsource.com/forums/...-chart-470588/ KC https://cimg8.ibsrv.net/gimg/themust...ee6145c2ed.jpg |
(Post 7084831)
https://www.americanmuscle.com/roush...s-0514-gt.html KC https://youtu.be/wyU1DkBdKrg |
the trick would be that you only want to lower the rear about 1/2" ... hard to believe that the AM listing on those springs does not say how much they lower; maybe check BMR for that info
most lowering springs are 1" drop or more, it may be hard to find 1/2" drop springs also the spring rates tend to be higher .... not sure how the car will ride with softer stock springs in the front and stiffer lowering springs in the back |
Originally Posted by Bert
(Post 7084859)
(Post 7084867)
We Used a Parking Block Back in The Day To Do That and I Actually Have a 71 LTD with a Parking Block in the Trunk. Been in There Since The 80's! :eek:
KC |
Originally Posted by wanted33
(Post 7084919)
Those may just work. At 190 bucks, that's not bad for something with the Roush name. Thanks bud.
(Post 7084919)
https://www.roushperformance.com/col...deb56c8b&_ss=c |
(Post 7084918)
It would probably be easier to garb a big 'ol rock, and put it in the trunk. That way I could just find the right rock to get 'er down a half inch. :jester:
