Help 2005 v6 4.0L mustang base - The Mustang Source - Ford Mustang Forums
General Mustang Chat Not Tech or Model Year Specific
Thread Tools Search this Thread
Old 6/16/17, 09:58 PM   #1
Hi i have a 2005 mustang v6 and it recently broke down on me. What happened was white smoke coming out the back end of my car i pulled over and my front end was smoking. It was raditor fluid everywhere. I looked it up and it said if radiator fluid is coming out your back end it is your head gasket blown. Couldnt get to it so we put it back together once we got to the temp housing we notcied a 5inch crack found the problem. Thats not all. We tried starting my car and it is rough it sounds like a straight pipe it boggles and it wants to shut off and over heat. Now i fixed spark plugs new wires new thermostat and temp housing crankshaft pulley and idler pulley and tensioner. Next is radiator because it is clogged which might solve the problem for the over heating. But that still leaves the issue of car being loud like a straight pipe it boggling while its idling and a vaccum leak and why it wants to shut off i have one code its p0340 camshaft sensor bank 1 circuit 1 or single sensor is this just the sensor thats causing the timing to be bad and the fuel injection or is it my timing?
Joe Idol is offline   Reply With Quote
Join The Mustang Source
Join TheMustangSource.com Today - It's Totally Free!
Are you a Ford Mustang fan? If so we invite you to join our community and see what it has to offer. Our site is specifically designed for you and it's a great place for Ford Mustang Fans to meet online.
Once you join you'll be able to post messages, upload pictures of your stang, and have a great time with other Ford Mustang fans. Whether your an old timer or just bought your Mustang you'll find that TheMustangSource.com is a great community to join. Best of all it's totally free!
Join TheMustangSource.com Today! - Click Here JOIN FOR FREE
Old 6/16/17, 10:00 PM   #2
I have a magna flow exhaust and it never sounded so loud what could be this issue?
Old 6/17/17, 02:34 PM   #3
I tweaked the button...
...and got lucky!
houtex's Avatar
White smoke coming out the back end is not good. Overheating to that degree on top of it all is seriously bad. That's a blown head gasket at the very least, a cracked block at the worst. and a 5 inch crack already found... yeah.
In any event, it's a *very* major issue with your engine. The other symptoms are all results of the problem: The engine is likely toast jam and jelly... aka 'done'. Stop trying to fix it unless you're willing and capable of doing an engine teardown to find out what's going on, or just swap out the entire block. Take it to a shop and have it dealt with right. Shotgunning it and throwing things at it is just going to cost you money and time and still not fix it.
I could be wrong. I could be off base, but the description as put indicates it's very bad.
I know it sucks. But truth is truth. Sorry man.
houtex is offline   Reply With Quote
The Following User Says Thank You to houtex For This Useful Post:
wanted33 (6/18/17)
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010, The Mustang Source
