Check engine light
Sometimes my check engine light will come on for no apparent reason then go off after a couple days, why would this be? When I had to codes pulled nothing came up. I drive a 2012 mustang 5.0, with bbk cold air, and flow master exhaust. Admittedly I do drive a little crazy. But what mustang owner doesn't?
Gas filler door not sealing well, causing an evap leak?
Originally Posted by SpectreH
(Post 6979028)
Check for codes while the light is on, if you haven't already done that.
