check engine
check engine
I have a 2015 ford mustang ecoboost. I have noticed that engine light comes on and off sometimes. When on I checked with scanner like 9 codes came up ranging from the map sensor to the turbo and a/c. P0236, P051C, P0645, P06A0, P0A5C. A/c does not work. I replaced the MAP sensor on the inter cooler and it was fine for a while but then it started to go off and on. Someone told me that it went on power sleep mode!
https://themustangsource.com/forums/...ensors-546093/
Why are you starting a new thread nearly two years later?
The reply in there is the correct answer: Get to a dealer and get them to figure it out. You've got a big electrical problem going on.
