Anyone know how the oil life monitor works and how accurate it is?
I've never had a car with one of these. Oil change clocks yes, but a sensor system no. How does it work? An engineer friend suggested it measures electrical resistance in the oil. That seems plausible as metal particles and other contaminants build up in the oil. Does anyone know how it actually works? Can it be trusted? My 12 GT is 2 months old, has 1700 miles and still has 85% oil life?
Originally Posted by redneb
(Post 6345033)
I wouldn't really focus on the percentage...
I go 3,000-4,000 between oil changes, and then reset it.... |
It probably works off the amount engine load & miles driven
(Post 6345277)
Here you go, from the Ford site:
More than likely, if you stayed on top of your required maintenance duties, you’ve changed your oil every 3,000 or 5,000 miles. With the introduction of the IOLM, now you’ll be able to take your vehicle in for an oil change based on actual operating conditions. What the IOLM measures to determine when an oil change is needed Several key factors that affect oil life include: Driving habits (such as towing and workload) Hours in operation and at idle Oil and coolant temperature Engine speed and torque Diesel particulate filter (DPF) cleaning cycles How the IOLM works The IOLM does not use oil quality sensors – it is entirely software-based and uses actual engine operating conditions to calculate the oil change interval by using an algorithm. This means the system must be reset after an oil change. Not doing so will result in a premature OIL CHANGE REQUIRED message. The frequency of oil changes Depending on driving conditions, oil change intervals are approximately: Up to 10,000 miles - Normal commuting with highway driving 5,000 – 7,500 miles - Trailer tow/high-load driving 3,000 – 5,000 miles - Short trip usage, extreme cold or hot temperature NOTE: Actual mileage will depend on your specific driving conditions. Under normal conditions, you will get an OIL CHANGE REQUIRED message at up to 1 year, or 10,000 miles from the previous oil change. What the IOLM tells you You’ll find a display in your instrument cluster’s message center that will notify you of oil change intervals by displaying ENGINE OIL CHANGE SOON or OIL CHANGE REQUIRED. The system will also indicate when fuel filters need maintenance, or if fuel pressure is low.* *Refer to owner’s guide for specific applications. Synthetic oil and the IOLM Ford engines have been tested using Motorcraft® Synthetic Blended Oils. If you do use synthetic oil, it needs to meet the Ford specifications for motor oil and the specific oil weight as indicated in the owner’s guide. Ford still recommends using the oil change service intervals as indicated by the IOLM. Vehicles that will get the IOLM The IOLM will be available on most vehicles under 8,500 lbs. gross vehicle weight rating (GVWR) and the all-new 2011 model year 6.7L Power Stroke® Diesel on the Super Duty® model. That translates into over 90 percent of the 2011 model year Ford, Lincoln and Mercury vehicles sold. For in-depth details about the IOLM, please refer to your owner’s guide and diesel supplement. Motorcraft® is a registered trademark of Ford Motor Company. |
More than likely, if you stayed on top of your required maintenance duties, you've changed your oil every 3,000 or 5,000 miles. With the introduction of the IOLM, now you'll be able to take your vehicle in for an oil change based on actual operating conditions. What the IOLM measures to determine when an oil change is needed Several key factors that affect oil life include: Driving habits (such as towing and workload) Hours in operation and at idle Oil and coolant temperature Engine speed and torque Diesel particulate filter (DPF) cleaning cycles How the IOLM works The IOLM does not use oil quality sensors - it is entirely software-based and uses actual engine operating conditions to calculate the oil change interval by using an algorithm. This means the system must be reset after an oil change. Not doing so will result in a premature OIL CHANGE REQUIRED message. The frequency of oil changes Depending on driving conditions, oil change intervals are approximately: Up to 10,000 miles - Normal commuting with highway driving 5,000 - 7,500 miles - Trailer tow/high-load driving 3,000 - 5,000 miles - Short trip usage, extreme cold or hot temperature NOTE: Actual mileage will depend on your specific driving conditions. Under normal conditions, you will get an OIL CHANGE REQUIRED message at up to 1 year, or 10,000 miles from the previous oil change. What the IOLM tells you You'll find a display in your instrument cluster's message center that will notify you of oil change intervals by displaying ENGINE OIL CHANGE SOON or OIL CHANGE REQUIRED. The system will also indicate when fuel filters need maintenance, or if fuel pressure is low.* *Refer to owner's guide for specific applications. Synthetic oil and the IOLM Ford engines have been tested using Motorcraft® Synthetic Blended Oils. If you do use synthetic oil, it needs to meet the Ford specifications for motor oil and the specific oil weight as indicated in the owner's guide. Ford still recommends using the oil change service intervals as indicated by the IOLM. Vehicles that will get the IOLM The IOLM will be available on most vehicles under 8,500 lbs. gross vehicle weight rating (GVWR) and the all-new 2011 model year 6.7L Power Stroke® Diesel on the Super Duty® model. That translates into over 90 percent of the 2011 model year Ford, Lincoln and Mercury vehicles sold. For in-depth details about the IOLM, please refer to your owner's guide and diesel supplement. Motorcraft® is a registered trademark of Ford Motor Company. |
(Post 6345278)
That's old school man
Originally Posted by cdynaco
Yeah - 3-4k is stupid under most conditions. Plus they are not thinking of the larger capacity of the 5.0 - which takes longer for contaminents to affect the overall condition of the oil. |
that kind of thinking.. change the clutch while you are at it.
FYI -
Originally Posted by Carey Holzman
(Post 6979814)
