67 mustang
Hi guys!
I bought a 67 mustang, needs some work apparently! Well I took the cluster out and noticed there was nothing at all hooked up in the back there, nothing wired into the actual cluster system. I put bulbs in the signals light area and rear light as nothing was working (no bulbs). Well here's what I get: Only works on hazards! Left hood works Right doesn't Front signals both work but again only on hazards Rear lights both work on hazards right side is much more dim than left?! Licence plate light was flashing too with the rear ones. Again they only work on hazards or four ways! I still have not put the cluster back as I'm not sure what is what behind there! :( not sure if signals aren't working because cluster isn't plugged in. As you can see I'm in need of some help here. I'm reaching out to see if anyone out there had a dummies down wiring or how to or any advice that will help me get it going here! I am also in the process of taking out the starter and changing out the thermostat! |
I look for stuff on toutube and its helpful.
Good luck! |
Youtube..
Oops |
| All times are GMT -6. The time now is 08:55 AM. |
