Convertible Top malfunction
I have a 2000 Mustang GT Convertible. I've never had a problem lowering or raising the convertible top. Yesterday like always the top retracted without a problem. When I arrived home and went to put the top up I had no reaction when I pushed the electric switch. I checked the fuses and all checked out to be fine.
My questions:
What are the possible causes of this failure?
Can I manually raise the roof mechanism? Where is the location of the roof locking mechanism so I can disengage it?
Thank you,
STILL NO POWER TO THE CONVERTIBLE TOP MOTOR, will locate motor to see if wire disconnected. Thanks for your help.
My questions:
Thank you,
Last edited by kgebro; 11/18/10 at 09:26 AM. Reason: I've since been able to manaually raise the top.
Welcome to the site.
Sounds electrical. probably lost a connection somewhere if it worked fine then all of a sudden you don't have anything. I don;t know the first place to look other than the switch and fusebox. someone with more experience then me can hopefully help you out.
