2009 Mustang GT No Start
Old Sep 17, 2023 | 01:39 PM
transamjoe's Avatar
2009 Mustang GT, 54k miles, 4.6 w/Kenne Bell Supercharger
Car has been running fine. Started a few days ago and pulled out into driveway to let it warm up. After 10-15 minutes it died and will not restart. Been a few days and still will not start. cranks, but no start
Old Sep 17, 2023 | 02:33 PM
05stangkc's Avatar
Welcome,
Deleted Double Post For You!
First Thing to Check if it is a Fuel Delivery or Spark Problem. Have You Tried to Spray Some Starting Fluid in Throttle Body and See if it Kicks??
KC
Old Sep 17, 2023 | 03:56 PM
transamjoe's Avatar
Welcome,
KC
I have tried but no luck. The fuel pump comes on and registers about 50 lbs on my gauge but curiously I don't smell any fuel at all. I have just now replaced the crank position sensor and still nothing. I have taken a spark plug out and with a spare new coil there is no spark.
Old Sep 17, 2023 | 04:14 PM
05stangkc's Avatar
Do You Have Any Kind Off Aftermarket Anti Theft Device???
KC
Old Sep 17, 2023 | 04:19 PM
05stangkc's Avatar
Also When Turning Key To Run Position Does The Factory Anti Theft Light Far Right Red Go Out After a Few Seconds or Stay on??
Are You Able to Pull any Trouble Codes???
Have You tried a Hard Reset with PCM By 5 Minute Battery Disconnect??
KC
Old Sep 18, 2023 | 03:10 PM
m05fastbackGT's Avatar
Also consider connecting a hand-held scanning device to your OBDII port to scan for any potential trouble codes... If any trouble codes show up? go over to google and enter them in as a search... The search results will provide an explanation for the codes along with several troubleshooting solutions.
Moosetang
Apr 25, 2007 12:55 PM
