which is better? The sheep or the wool??
How old is the sheep?
can you creep up on a sheep while It`s a sleep .
Why do you use a grave accent (`) when writing It's instead of an apostrophe (') ??
what is a grave accent ` ?
WTH?
WE
THE HATERS?? alright so while putting the hard to get to bell housing to engine bolt, I missed the bracket with the bolt. So the bolt is in and tight. Question is should I take the bolt back out so I can put it through the bracket orrrrrrrrrr just zip tie the bracket? |
yes ,,,,,
Yes what?
Did you not follow the thread?
what did one mustang driver say to the other mustang driver?
Did you not follow my tread?
was there a thread here to follow?
Does a seamstress follow the thread?
ha you get me.... it's this thread right?
http://www.webbikeworld.com/motorcyc...hread-file.jpg right hand |
Originally Posted by Glenn
(Post 6858324)
Are you all tapped out?
Can you play Taps on a bugle?
Does a bugle play when you tap out?
