Wiring help
Wiring help
I'm installing the new Steeda front fascia and Hella Fogs with it. I need to tap into the low beam headlight wire......anyone know which one it is? Green, Black or White? I don't have a tester kit, and don't want to start stripping wires and playing the guessing game. I've got everything else hooked up...just need this last piece to the puzzle.
Thanks in advance for any help!!!!
By the way - if you order this, I'm less than thrilled with the way the fogs mount in the fascia - so I had to buy some aluminum and build a better bracket than what was supplied.
This is from the 2005 Mustang wiring diagram:
Attachment 3945
So, it looks like you can tap into the Light Green with a White stripe wire for the right headlight, or the White wire for the left headlight.
Hope this helps...
Attachment 3945
Hope this helps...
Sep 23, 2015 03:21 PM
