What do people use to clean the rocker panels..
For quick & easy I would try Pine-Sol.....it removes sticky tape residues and such, and seems like it would work for your needs too, and it would be easy to use at the same time you want to wash your car. I wouldn't use the pine-sol on any more than your rocker panels though. They make bug & tar removers, but like waxing your car, it takes a little more time.
Once you get those areas clean be sure to give those areas a couple of coats of wax and keep it waxed often.
It will make it a lot easier to get the bugs and tar off in the future. Plus check it every other day and when you see some take a few minutes to clean it off before it has a chance to dry hard as a rock.
For a lotta tar Simple Green and a sponge. And turtle is great for bug and tar remover...been using it for a long
I tried this and it got about 40% of it off! I'm staying away from the "wife" comment in case she is reading...LOL.
I use McGuire's Professional Mirror Glaze 3, or M3 as its known in the detailing business. Its a polish, that isn't abrasive, and it removes basically anthing on a car, from tar, to road grime. I used it this weekend, and it took everything off inside the wheel wells, and on the lower rocker. I recommend this stuff, but you have to get it online. You can't find it in any store. Hope this helps.
Wax wax and wax(or maybe a detailer). Don't use household cleaning products. They are not made for car paint jobs and can do damage. If you must, use a bug and tar remover. But wax will usually do the job. I just cleaned a bunch of tar off my car this weekend cuz they were paving the roads by my work.
After all these years,
My C/T still sucks!
My C/T still sucks!
Little bit of both. I got angered when they were repaving my neighborhood and blocked my street so I stupidly peeled out on fresh asphalt. The wd-40 removed most of it, but what it didn't you can not see.
The remainder is my stupid tax.
MR Clean Auto-dry car wash system is by far the best cleaning system I have ever used. It is 99% successful at removing bugs, tar and the occasional ros kill bits form all of my vehicles. It doesn't always dry quite the way they say on coopl days or damp evenings, but it does clean nicely and leaves no spots. Get a good microfiber cleaning mit or sponge. NXT wax is awesome and the NXT spray detailer is a great touch up. It is also very effective at removing bugs.
