V6 Question ?
Old Nov 27, 2004 | 09:40 AM
André's Avatar
Does anybody know what kind of differential the V6 base Mustang has ?
I'm not reffering to the optional antiskid with abs...
Is it some kind of limited slip or locked differential ?
Old Nov 27, 2004 | 10:41 AM
schoonover_88's Avatar
No, the V6 differential is not a limited slip diff. or locked in any way for that matter (to my knowlege).
Old Nov 27, 2004 | 02:17 PM
Falchion's Avatar
Does the V6 have a different differential if you have the ABS?
Old Nov 27, 2004 | 02:23 PM
No, I'm pretty sure that they use the same 7.5 inch diff. in all V6's no matter what the options.
Old Nov 27, 2004 | 02:44 PM
Falchion's Avatar
OK, thanks....
Old Nov 27, 2004 | 02:55 PM
orange3.9stang's Avatar
You can easily swap out the open differential with a Ford Motorsport Traction-Lok # M-4204-C75. Typically you can find one from an online vendor for under $200.00. I friend of mine builds differentials and he did the swap for me for around $50 (I brought just the axle assy. to him).
With less than 100 miles, it was the first thing I did on my 2004 and again it would be if I were to get a 2005+. Perfomance tires (BFG KDWS 225/55), Magnaflow Dual Exhaust, and B&M Ripper Shifter also went in at the same time.
Old Nov 27, 2004 | 03:50 PM
Falchion's Avatar
Interesting, was your 04 a V6?
And I was thinking about getting the BFG KDWS tires as well. How do you like them?
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
MustangConvert11
Sep 30, 2015 08:01 PM
