-   2005-2009 Mustang (https://themustangsource.com/forums/f637/)
-   -   Is this true? 2007 Mustang GT Slower? (https://themustangsource.com/forums/f637/true-2007-mustang-gt-slower-450379/)
GTJOHN Apr 10, 2007 07:30 AM
From Wikipedia
The 2005-2006 Mustang GT is capable of performing a quarter-mile test in 13.5 seconds, with acceleration from 0-60 mph in 4.9 seconds.[8] The 2007 Mustang GT, reflecting an increase in weight from the 2005-2006 model years, runs a quarter-mile test in 13.9 seconds at 103 mph, with acceleration from 0-60 mph in 5.3 seconds.[7] Additionally, the '07 Mustang's front suspension is revised to improve steering response. Added to the rear suspension is a three-linked system which controls the vertical and lateral movements of the axle. All model years of the S-197 Mustang retain a live axle rear suspension providing the benefits of reduced cost and weight over a heavier, more expensive and complicated independent rear suspension, at the expense of more efficient handling. The 2005-present Mustang GT also comes equipped with a limited slip differential complete with the same carbon-fiber clutch discs used in the 2003-2004 SVT Cobra and the 2007 Shelby GT500. The differential is designed for the 31-spline axles and the 8.8" ring gear used in the S197. Unlike the Mustang GT, the basic V6 model without the 2006+ Pony Package lacks a rear anti-sway bar to prevent severe oversteer on hard cornering.[9] The 2007 Mustang V6 and GT chassis, suspension, and body shares many of the same construction designs as the GT500. Thicker sheetmetal support and extra welds can be found on the 2007 chassis. Re-designed strut towers on the '07 Mustang accommodate the wider 5.4 L 4V V8 engine in the GT500. Another example is the rear diffuser from the 2007 GT California Special package (GT/CS), also used for the GT500.
G.T Apr 10, 2007 07:50 AM
i believe it's true
if you compare the base models.. 2005-2006 came with a 3.55 rear end gears, while the 2007 comes with 3.31:1 (3.55:1 are optional)
so in theory the 2005-2006 should accellerate a bit faster
robair Apr 10, 2007 08:53 AM
Hearing that, I'm glad I didn't wait and got my GT in '05!
GTJOHN Apr 10, 2007 09:22 AM
Although the car appears to be improved, I am not happy about it being slower(if true).
G.T Apr 10, 2007 09:39 AM
it's not like you can't pay the $100 USD extra and get the optional 3.55 gears same as the 05-06!
sycd Apr 10, 2007 09:41 AM
If the rear-end ratio is really the culprit, then that's easy to fix, just buy a car with the 3:55 rear-end, it's just a $100 option.
Also personally I wouldn't draw just definitive conclusions from just two test results. Conditions might have been different, drivers might have been different, there are slower and faster cars, etc.
holeshot Apr 10, 2007 09:44 AM
4 tenths of a second difference. What would that equate to....half a car-length?
Giddyup Apr 10, 2007 10:09 AM
Me too, except I got mine in late '04....:nice:
RRRoamer Apr 10, 2007 10:11 AM
At 100 mph, 4 tenths of a second is almost 59 feet.... That is a LOT more than "half a car-length". Almost FOUR car-lenths...
In my book, that is a LOT slower.
blackhat Apr 10, 2007 10:26 AM
Remember, Wikipedia is made up of volunteers supplying the info. Anonymous volunteers at that. Take it for what its worth.
But yeah, that makes sense about the gears.
mot250 Apr 10, 2007 10:34 AM
The added weight (heated seats, satelite radio, other new options) don't help any either. Add a tenth of a second for every additional 100 pounds as a rule of thumb...
FRITZ Apr 10, 2007 10:40 AM
I had an '05 GT auto 3:31s, now i have a '07 GT/CS 3:55s manual. I think just from SOP's the '07 seems a tad faster. It also has no rattles (so far) that the '05 had, all and all it seems a lot more tight...just my opinion
metroplex Apr 10, 2007 11:20 AM
I added the info about the new chassis/sheetmetal that I learned from TMS, but some moron keeps using magazine tests as gospel for performance figures. I think he's secretly a F-body Camaro owner. And yes, anyone can modify the info which is a good thing and a bad thing.
shatter Apr 10, 2007 01:16 PM
Sounds like a 2005/06 owner is butt hurt over the 07 having some new options and wants to bash it. That is why I rarely trust wikis. :)
RomaTX Apr 10, 2007 06:25 PM
if 4 tenths of a second really matterd, i.e. you were racing the car for cash (professionally or otherwise) then it really wouldnt matter what came out of the factory cuase you would never leave it stock. so really, for most of us, that 4 tenths only matters when having those hypothetical conversations with camero and firebird owners.
shwaco1967 Apr 10, 2007 07:10 PM
So? You won't see me whine because my car is any kind of tenths slower.:rolleyes:
Fireball1 Apr 10, 2007 07:12 PM
My guess is the 4.9 second 0-60 run was from an early Mustang specially prepared for magazine testing. The later 5.3 second 0-60 run was from a heavily optioned California Special with side scoops, lower fascia, diffuser, dual power & heated seats, perhaps trunk amplifier/subwoofer and other options that add weight. Probably equally equipped 2005 and 2007 Mustangs purchased off a dealer lot would accelerate similarly.
karman Apr 10, 2007 07:44 PM
I don't believe the 2005 was specially prepared.
I don't think it was heavily optioned.
I do think it was run in cold fall/winter air with a very good driver.
hamstang Apr 10, 2007 07:55 PM
In the world of drag racing 4 tenths of a second is FOREVER!. Folks pay big money to reduce their ET by that amount. Just though I'd put the proper perspective on that issue
metroplex Apr 10, 2007 07:55 PM
I think Fireball is right. It was a heavily optioned out 2007 GT/CS and probably not broken in yet.
