Speedhut Gauges installed!
Well in preparation for my SC install, I wanted to get some gauges installed. So I wired them up last night, still have to hook up the senders just power for now, though you'd might like to see them.
Going with a Boost/Vac, A/F WB, and Fuel Pressure. http://www.youtube.com/watch?v=QTyNhmj6v5w |
Very cool Starfire! How easy was the install? BTW....do you have the "leather/vinyl" dash or standard? I'm curious, because I hadn't seen anyone do the dash mount gauges with the "leather/vinyl" dash.
where did you draw your power from i have 3 gauges i need to run and have no clue where to get the constent 12v after crank at..
From the smart junction box under the passenger kick panel the are 3 open fuses and the farthest to the back of the car is a live after ignition wire. Just use an add a circuit
ill post more when I get home |
What kind of center pod do you have? How did you run your wires?
I'll post more when it's light out, it's dark now so can't see that well, but yeah that's the autometer pod and the speedhut revolution gauges I had them put on the GT/CS
http://starfiregraphics.net/gauge1.jpg http://starfiregraphics.net/gauge2.jpg |
