S-197 Convertible Top Issues / Window Motor Pdf's, LOTS OF FACTORY SHOP MANUAL PDF'S
Old Jun 19, 2023 | 05:33 AM
Eliminator.dk's Avatar
TMS Denmark S-197 Fan
Hi.
currently on vacation in south germany, and this problem started day 2. The soft top don`t raise in the right side. ?
anybody seen this problem before and maybe a fix for it. ??
2005 GT
Old Jun 19, 2023 | 08:20 AM
05stangkc's Avatar
  • The convertible top does not operate correctly
  • Convertible top frame bows
  • Convertible top side rails
  • Hydraulic fluid leak
  • Hydraulic lift cylinder
  • Hydraulic motor and pump assembly
  • Low hydraulic fluid
Shop Manual Troubleshooting.
@Eliminator.dk
I Believe Issue is in Hydraulic System. Perhaps this Will Be Helpful! Sorry These are Online Interactive Pages and Somewhat Limits Usage.
If Anybody has Had This Issue Please Chime In!
See Section C1 in PDF3
KC
File Type: pdf
File Type: pdf
File Type: pdf
Old Jun 19, 2023 | 08:29 AM
NC14GT's Avatar
Hmmm. doesn't look good in the movie you posted but make sure nothing is binding up. Have someone else operate the top while you look it over and "give the top some help lifting it up". Also make sure the joints are oiled or lubed and not too dry. Keep a rag towel under each section to keep the oil from getting all over the place. You can even use WD-40 and the towel will catch any overspray. Use another small rag to clean any excess from the joints you oiled. Simple enough tips but easy to overlook. No need for a mess. Good luck!
Old Jun 19, 2023 | 08:54 AM
05stangkc's Avatar
Checking For Binding Certainly a Consideration!
KC
Old Jun 19, 2023 | 09:21 AM
Thank You guys , i`ll do something possible here @ the vacation camp. …..But maybe first find a solution , when i get home in the garage. 😄
thanks for instruction pdf as well.
thanks again. 👍👍
Old Jun 20, 2023 | 01:33 AM
Hi.
Yes, my wife help to lift roof in the right side, and it`s possible to close it that way.
Do you think it can be done that way multiply times, without damage ?
Old Jun 20, 2023 | 07:29 AM
05stangkc's Avatar
Originally Posted by Eliminator.dk
Hi.
Without Knowing What is the Issue It Would Be Difficult to Say if it Would Cause Damage. I Would Be Looking Around For Fluid Leakage as Every Top Cycle Could Be Draining More. Unless it is Just Air in the Lines.
KC
Old Jun 20, 2023 | 07:35 AM
NC14GT's Avatar
It's probably fine to do that manually if not forcing anything. Eventually something will probably break if done too many times. The glass is always scary.
Good luck finding the cause and we hope it's not too serious or expensive.
Old Jun 23, 2023 | 09:18 AM
When I watch now, I can see the roof can`t hold pressure. No of the sides. Do You know if a checkvalve is in the system , and if a fix is possible ?
nothing is leaking. ?
thanks : Henrik
Old Jun 23, 2023 | 12:27 PM
05stangkc's Avatar
thanks : Henrik
I believe a Fluid Check & Bleed of The System would Be The First Thing I Would Try. See PDF.2
BTMO,
KC
Old Sep 20, 2023 | 06:45 PM
05stangkc's Avatar
@thejak I Noticed Your Search Earlier & Thought These Might Be Helpful!
I Have Added More Content For Other Convertible Top Issues Besides Hydralics. Be Advised the S-197'S Tops Were Very Similar from 2005-2014. 2007 Factory Ford Shop Manual Sections!
This is Not For OP Concern But Others Seeking Convertible Top Information! I Should Have Started a New Topic! But I Did not! DOH!
Top Removal & Installation, Headliner, Bows Etc.
Enjoy,
KC
Old Jul 18, 2024 | 02:10 PM
05stangkc's Avatar
WIndow Motor Integration Information
2005 Mustang Window Wiring Diagram.
KC
File Type: pdf
rocket7888
Apr 2, 2021 11:37 AM
2_CW_2
Jun 2, 2012 01:27 PM
topbliss
Oct 27, 2011 08:50 AM
keeper
Feb 9, 2008 02:58 PM
Adam8g
Jan 23, 2007 12:13 PM
